21 - 40 of 47 Posts
Very safe, maybe overkill. Dustless blasting is good as well. It’s glass bead in water. I used coal slag from a distance and it didn’t distort
Discussion Starter #29
It's been a couple of big days doing the tear down on the rig. The corner bolt/screw between roof and the windscreen...worst so far
459818
Discussion Starter #33
I had a bit of trouble with the wiper/wash spine as it appears one of the wiper arms was epoxied in place...
459828
459829
Discussion Starter #34
Finally a better look at the chassis and transmission. Modification to the exhaust for Disco 200TDI is visible.
459830
459831
459832
459833
Discussion Starter #36
A
I don’t see any rust penetration. Remove, clean, galvanize, paint
Edit: I do see the hole on the long run. Patch if you can. Then galvanize
Whats the best suggestion on patching? Just stick? Then galv?
21 - 40 of 47 Posts
