1 - 5 of 5 Posts
Can someone tell me how the AC controls work on an 88 LHD with factory AC? I am pretty sure I have an issue but need some help diagnosing. When I use the selector lever to move air to come out the dash vents the air continues to blow out the defrost vents. It used to eventually switch to the dash vents but seemed to have amend of its own, switching between dash and defrost on its own. Now it just comes out of the defrost. Is there a motor or vacuum hose to activate the plenum doors? Does not appear to be cables
Thanks in advance!
I assume that means I need to take out all the dash fascia - the part with the vent louvres in it? Is there any other way to get to the hoses? Anyone have diagrams or pictures that show how it should look?
I assume my vacuum lines are bad and potentially a vacuum motor or two. Are these worth fixing or should I scrap the dash system and go for the newer style systems? Will I need to get this working in addition to adding the newer style to the truck?
1 - 5 of 5 Posts
