My truck is in North Florida and I don't have a knowledgeable shop in my area to diagnose what is going on or parts availability. My left front tire leans inward and not straight. I need to know what parts to order so I can have a local shop address it.
Is the axle bent? No camber adjustment on these, I would imagine the only other reason would be a swivel ball issue or bent wheel
You need to put an angle gauge on the axle lange to see if the axle casing is bent. If that is straight then look at the swivel flange and the last possibility is the stub axle.
I don't think the axle is bent I was headed in the direction of redoing both swivel balls with a kit from online.
Kingpin (swivel) bearings?
