1 - 13 of 13 Posts
I replaced the 4 nozzles with original Bosch ones. I have now MUCH LESS SMOKE:) At high speed it runs smooth and power feels good. Not more powerful than before though despite the less smoke that it produces.
But, when idling it sounds like one cylinder is not contributing. I loosened the fuel nuts one at a time and it looks like engine doesn't miss so much when nut on cylinder 4 is loose. Ideas will be welcome
United Diesel over on General Washington Dr. (Alexandria) *should* be able to check the cracking pressure and spray patterns I'd guess.
If not, I have a guy (Tom Bryant) up in Maine that will do this for ~$40 if you ship the injectors to him. Shoot me a note if you want his contact info.
Yeah, just went through a bunch of injector malarkey. Don't even bother messing with them, just send them off to get tested and adjusted as necc.
Blue Ridge Diesel can do it as can any of the other listed shops I believe.
Pablo:
It sounds like your engine has a leaking injector.
This happens when an injector fails to close and constantly leaks fuel before and after the given pop-pressure that is suppose to open the injector at a pre-defined pressure.
Blue Ridge can check it or your local guys...
The 200TDI is 2 stage. so some shops may not be equipped for these... best to check first.
Discussion Starter · #12 ·
Pablo:
If the injector is leaking it must be because I assembled it wrong?... with the old ones it smoked but ran and idled smooth. Also, Is there a known shop that has the ability to service these 2 stage injectors? Blue Ridge?
Thanks!!
1 - 13 of 13 Posts
