1 - 5 of 5 Posts
I recently replaced the head gasket myself on my 200tdi by the book - all new hardware, had the head professionally refinished, Elring gasket etc. The truck ran great for several hundred miles and then when cruising on the highway I experienced an abrupt loss of coolant (with some leaking in through gaps in the firewall).
I initially thought that the head gasket might have gone again and immediately had it towed home - however after topping off the coolant to see if I could find a leak, it appears that the frost plug is missing off the back of the head - as coolant was just flowing out of that area.
It doesn't appear like there is coolant in the oil, however I turned the engine off immediately and have not run it again since the incident.
Is this common/possible that I just blew the plug out of the head? Can a new one be fitted without removing anything or do you think that I may still be having other head gasket issues as well?
Thanks for any insight !
I can’t imagine how you’d access that without removing the head. There’s also a core plug in the back at top of the block, i.e., right below where the head mates to the block. Be sure it’s not that one.
It’s definitely the one on the head. I removed the lift point/bracket which freed up some room but not sure it’s enough… might be able to make a tool and “pull” a new one in towards the head?
1 - 5 of 5 Posts
