1 - 4 of 4 Posts
Looking to rent this tool. Can’t justify buying for one time use. Thank you!!
Do you mean the crank pulleys on the outside of the timing case or the crank timing gear inside ?
If outside can be done with a universal puller from AutoZone and a big washer on the crank nose
Outside, that’s good intel!
Yep , remove the four m8 bolts that hold the pulley to the damper. Then use the universal puller by putting a heavy washer on the crank nose , smaller than the damper but large enough to protect the threads of the crank nose. Will pull right off .
Also you can try carefully putting a pry bar behind it and tapping on the bar . Be careful not to crack the timing case .
1 - 4 of 4 Posts
