1 - 11 of 11 Posts
Rookie question here - New battery just installed and battery warning light still illuminated. Are the intelligence there to tell me that the Alternator is bad or could this be a wiring issue?
Check all wiring connections to the alternator and engine ground. If you have the type with the voltage regulator/brush pack that screws on the back, pull it off and make sure the brushes are not stuck.
While you are there...
PS belt.
Dayco 17285
13mm x 28.5"
One day I should put together a North American parts list for the 200TDI Defender.
While you are there... PS belt. Dayco 17285 13mm x 28.5" One day I should put together a North American parts list for the 200TDI Defender.
seriously! im slightly amazed the indie vendors haven't pulled together a recommendation list. it certainly seems it would help speed up the purchasing process, idk.
1 - 11 of 11 Posts
