So I just pulled my 2.5 na motor and gearbox as part of a complete restoration I’m doing. Everything runs fine and I’ve actually been really happy with it. I know its slow but its fine for what I need and want (I’m not interested in a swap on this truck). The only complaint I have is it burps a little bit of oil out of the breather cap. Its not a lot of oil so I don’t know if its a symptom of a larger blowback problem or just a loose cap or seal? I’ve heard people having success with installing a splash guard inside the valve cover to deal with this but I don’t know much about it so if anyone has experience with this I would like to hear about it.
I’m looking for ideas on preventative maintenance that I should do while it’s out keeping in mind that I don’t want to do a complete rebuild due to time and money constraints but if you feel that’s important go ahead and try to convince me!
Here’s a list of things I’m thinking of doing and wonder if you have any suggestions or additions that make sense to do now as opposed to when the motor is installed?
1. Change all external belts
2. Replace timing belt
3. Clutch
4. Address oil burping from breather cap
5. Paint the block
6. Crank seals
7. Complete fluid change (of course this could probably be done easily after install too)
Anything else you would do that I’m missing? Thanks for the feedback!
3. Clutch
5. Paint the block
6. Crank seals
