1 - 8 of 8 Posts
I have had these and have good luck selling alternator by itself, injection pump by itself, and the PS pump/adjuster bracket/mount as a unit, and then hauling block in for scrap.
Do you pull anything off the LT77 before you scrap it?
You can cut off the input shaft if it's in good condition and use it as a clutch alignment tool
If flywheel has a notch in line with dowel for TDC, (will have two notches, can be used on other engines.
100% shift linkages
And yes on clutch align tool.
If you are picky enough, front cover, rear cover, valve cover and anything else aluminum for separate alu scrap pile.
One drivetrain is not going to net you a lot of money, but it all ads up and I kinda like to be a little green WRT my automotive wastes! I buy old barrels off CL and when full off they go.
1 - 8 of 8 Posts
