1 - 5 of 5 Posts
I have a 2.5 NA Diesel that I have a new 300 TDI ignition switch for. Does any one know how to adapt it? Does it require a relay for the glow plugs? IS it possible? Thanks!
For the old switch, this is the wiring and the plugs it corresponds to:
1. White -Ignition
2. Brown/Red - Glow Plug
3. White/Black - Solenoid
4. White/Red -Starter
5. Brown - Perm 12V
For the new Switch
1. Red/White - Starter
2. Brown - 12V
3. White-ignition
4. Blanked out. (no terminal)
5. "Accessory"
You dont have to change it to the later setup but you can. On the early trucks the glows are activated by the driver holding the key against a spring loaded portion of the ignition switch. On the tdi's the glows are operated by a 10 xecond timer relay activated by tirning the key to the run position. You would need the gow plug timer relay and the later switch.
Ok, this is the later switch, and I do have the glow plug timer relay. I suppose I would just run one of the wires that is active while the "run" position is on, to the glow plug timer relay (plug 3 -ignition) on the new switch?) Thank you for your assistance Uncle Douglas!
1 - 5 of 5 Posts
