1 - 2 of 2 Posts
Hello. I just bought a defender and is in the process to do all the checks to get the roadworthy done to enable registration. I am asking for advise on what i should be looking in addition to the list below. I am planning the following at the moment:
- Oil changes - Diffs, gearbox, engine and filter changes (filters - Diesel, oil, Air)
- Replacing the following as a good measure
* Power steering pipes and reservoir - currently leaking)
* bearings
* shocks and springs (returning to standard - currently lifted)
* sway bar and ball joint bush replacement
* door handles and catch replacements and rubbers etc. and some other things, paint is coming up as well.
Anything else i should look at if you can recommend. I also need some assistance or recommendations on the instrument cluster. Some of the warning lights need replacement. do you replace with LED's or not etc.
Where is the truck? If it’s a 1999 your not going to register it here in the States for another 3-4yrs as it has to be 25yrs old.
1 - 2 of 2 Posts
