1 - 6 of 6 Posts
Been working through diagnoses of this issue for quite a while now. Took it to an event October of last year and all was great, drive it occasionally just because I love the damn thing. Got in it a month ago to go exploring for some fishing and couldn't get over 1250 RPM or so and if I floor the pedal it bogs down worse.
I have check for fuel, spark, went ahead with some new plugs and wires just because it needed to be done. Read some post that a bad alternator might be causing some issues so I got mine tested which tested on the bad side for regulator so I went ahead and replaced it. Fuel pump comes on as it should and seems to have good pressure at the fuel rail. Next thing I can think of is the ECM but not sure how to diagnose or if I am headed in the wrong direction. I do have access to another ECM via a dead D1 but didn't want to mess with that until I stuck the problem out there for suggestions. I have had the 90 for 4 years and other than a little lack of power at times it has always run like a top. I have dealt with the check engine light off and on due to the rough road sensors which has a few solutions i haven't dug into including some wiring to the speedo. That is another issue. Ran a code checker on it and only get the rough road sensor fault. I have read where I can put a D1 computer in and reset with the test book but maybe another day.
Thanks for any suggestions or ideas or maybe even a link to a similar post. Most I have found are not on the 97's.
Make sure there are no leaks on the big hose from the maf to the air filter housing.
Discussion Starter #4
I didn't notice any cracks or leaks but after reading another post I need to pull it off and check it completely. Thanks for note. On another thread from back in 2015 the end result/fix was from a broken trigger tab on the flywheel plate. seems crazy and not looking forward to pulling the transfer case and transmission just to check for that possibility.
Couldn’t you just check through the CPS hole? Did you check fuel pressure while it is actively having the issue such as when driving?
Discussion Starter #6
I checked the hose from MAF to intake and all is good with no cracks between MAF and air filter. I have not been able to check fuel pressure when accelerating and can't drive it due to no power. Another simple thing to double check and mark off the list.
1 - 6 of 6 Posts
