1 - 20 of 177 Posts
Figured I’d start a thread on this as I am going to do a number of projects on the 110 as it moves into daily driving status for me.
A rough list
LHD conversion + AC replace
Full exo cage
Holly sniper EFI
DUI distributor
New interior and seats
Maybe repaint
Discussion Starter #2
All the rest of the LHD major parts on order, including the Webasto interior unit.. only 4 vents though the current setup has 6 but everything under the hood looks the same, but i may need new lines.. we will see there is i can redirect them from the RHD to LHD location - looks possible..
The LHD steering knuckle is on (thanks brewie for the knowledge and shop space to do it, i was clueless at points) I have an order in to Zack for a new heater box (part to replace plus rust repair = it just easier for me to order a new one.
HD steering and the rest of UD’s LHD list are either reclaimed or on order. So after the next event i’ll Pull it into the garage and start the tear down and replace.
The LHD lower dash was disassembled and only the top plat needs replacement - and the seal which is a score.. i thought for sure it was toast..
the parts covered by the AC wil stay and the rest is good. Some surface rust removal and paint and its done.
ARB headlight wiring harness and horn harness (not ARB) are here as well. So will go in hopefully i have enough in the budget for headlights but we will see how the spitronics system moves or doesn’t.
Spent the past 3 days with Tech support troubleshooting and finally have a decide to idle and no rev correction after drving it. About the best we can do with the hybrid system it is, all the maps are good. I’m probably going to finish the conversion then go right into the Sniper and DUI setup. I need something supported (the spit is a 10 yr old system and pretty simple but not supported any longer. They are doing me a favor at this point)
love the color...
looks like a fun project
Discussion Starter #4
Thanks rob, I’m hoping the hardest bit will be the various lines that I have to get made up to move the fluids around.
Boxes have mostly arrived
And the dash parts are ready for touch up and install.
Still waiting on the ac in dash bits but looks like I can reuse all the engine side which is great.
Tearing into it now that everything has arrived.
I am really thinking I will go with a holly sniper and dui distributor on this one as well. The wiring for the fuel injection and most of the add-on stuff will have to be redone anyway.
The ac is out and once I fully pull the wiring harness it will be for sale.
Taking offers on it or trade for the above parts (sniper and dui hei distributor). It will come with the in cab components only. One vent is mugging out of 6 but looks like it is a davia one.
Good news is no real rust on the bulkhead esp where the clutch leaks normally and strips the paint.
I will be putting in a dormon SDO conversion to eliminate that
Discussion Starter #10
Doug, about that... there is a whole lot of ZA spitronics efi that is coming out... the wiring is down right scary. I got side tracked tonight making a plug for the bulkhead, removing the remainder of the ac, and ripping out wiring (it has a NL dual battery system that was not hooked up correctly, and a combiner/cutoff switch. I left the NL but removed the rest.
The current plan is to use a holly sniper, dui disti setup and dump the spitronics stuff.
I called their tech support and the guy was like... I’ll try but that unit is ancient....basically I can use one version of the tuning software, and it’s good luck from there. That’s enough to make me dump it.
They turned the plenum to route the throttle cable, it seems... I have no idea what they were thinking.
It’s a rebuilt 3.5 that runs strong though.
Discussion Starter #11
After a consult with Doug every thing is ready to cut out for the pedals... I have to move the steering wheel lug though.. and close the hole for the ac... borrowing a welder tomorrow.. should be interesting.
Ac wiring (sa system)
Gauge and heater wiring
https://uploads.tapatalk-cdn.com/
20181106/3eb79492fb93aacb4f6303fd06249711.jpg
Working right to left
Tach
Temp gauge
Fuel gauge
Heater fan speed
Everything is marked now for the switch.
Discussion Starter #14
Me too,
They might have to go or be modified. But hopefully not. I really don’t want that headache.
Discussion Starter #15
No-hand-drive!
The steering box is the last thing to be removed and then reverse assembly starts.
I’m going to finish raptor lining the wheel wells and paint some of the exposed bits black in the cabin. But probably wait on the engine compartment paint or just do a light job of it until phase 3 (new engine).
Discussion Starter #17
Unknown yet but probably an LS.
That is too far down the road to think too much about.
Discussion Starter #18
More removal as I start on the steering box and steering stuff in general.
Had to remove the modular bush guard, winch, and tray (all for sale) and extended nose.
Started on the steering, will be removing panhard rod and steering Sunday and the rhd box.
Then installing the lhd one and checking clearance with the headers. Hopefully I’m fine but may have to get them modified next week.
The mock up steering and move the bracket on the dash. And carry on
Discussion Starter #19
Looks like the headers need to be redone, just one pipe though. Bummer
But assembly has started.
Discussion Starter #20
Header off, and the steering rough assembled today...
Waiting on disco HD steering rods to show up to finish the Lower side of the install. Then cut holes for the pedals and steering column stuff.
Ordered new gauges (VDO) for that part of it and started on the lower dash top panel which I’ll have to fab.
Just a couple of hundred things to do now but it’s coming together.
1 - 20 of 177 Posts
