1 - 13 of 13 Posts
Landrover Defender 90 TDI 2.5L Diesel
This represents a rare opportunity to acquire one of the last of the iconic shape Defenders ever built.
Presented in superb condition throughout,
the jeep has one owner from new
Comes fully serviced (OIL,FUEL and AIR) and ready to go
Mechanically perfect, has no faults and has a US title.
A real head turner!!
-High/Low 5 speed gearbox
-Locking difs
-genuine Landrover towing pack
-genuine Landrover backstep
-solid roof rack with ladder
-Centre Armrest Cubby box
-4 rear foldable seats
-Brake and indicator lights upgraded to LED's
-Genuine Landrover Mud-flaps
It is otherwise original and comes with 2 sets of keys.
Have original UK reg plates
Has to be seen!!
Milage :168456
$35K ONO
No trades
443865
443866
443867
443868
443869
443870
443871
443873
Might i suggest you cater the ad to your audience? There is nothing rare about an RHD 90 and this is actually one of the first Defenders built not the last..
I mean, if you don’t count the trucks built between Jan 1993 and Jan 29 2016; this is among the last ever made.
There are some MOT advisories on corrosions, can you post pictures of the frame and suspension areas?
Advisory notice item(s)
  • Nearside Front Stub axle has slight vertical movement between stub axle and axle beam (2.5.A.1a)
  • Offside Front Stub axle has slight vertical movement between stub axle and axle beam (2.5.A.1a)
  • corrosion to chassis
  • Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
  • Offside Rear Brake pipe slightly corroded (3.6.B.2c)
  • Nearside Rear Brake pipe slightly corroded (3.6.B.2c)
  • Nearside Rear Suspension spring mounting prescribed area is corroded but not considered excessive (2.4.A.3)
  • Offside Rear Suspension spring mounting prescribed area is corroded but not considered excessive (2.4.A.3)
  • Nearside Rear wheel bearing has slight play (2.6.2)
  • Offside Rear wheel bearing has slight play (2.6.2)
  • Centre Rear Suspension arm has slight play in a ball joint (2.4.G.2)
  • steering box leaking slightly
I guess by the lack of response we will see this on BAT soon, honestly was trying to get some details as I am still looking for a solid Defender. Wife even agreed to shop while prices were dipping.
Well Rossco390, now that the ad executives, clairvoyants, proofreaders, and whiney bitches have deemed your ad worthy, I wish you good luck selling it.
1 - 13 of 13 Posts
