This 110 HCPU was purchased and imported by me. It has a clean NJ title and registration. This thing turns heads everywhere it goes.
All mechanical work done by George at Authorized Import Cars in Flemington NJ (the Rover guru in this area)
LINK TO PHOTOS and restoration photos Hemmings Listings for HICAP
This 1992 Land Rover Defender 110 truck has undergone a restoration starting in 2021 and finishing in 2022.
VIN: SALLDHHF8JA918390
Powertrain:
200 TDI with LT77 gearbox
56,XXX Miles (Ex Fire chief truck in France)
New timing belt
New water pump
New thermostat
New upper and lower radiator hoses
New radiator bleed pipe
New power steering box (very expensive and hard to find)
New valve cover gasket and breather
New exhaust midpipe-back
New rear A-Arm ball joint with stainless hardware kit
New fuel filter and misc. fuel tank fittings
New Clutch master cylinder
New Clutch slave cylinder with stainless uprated hose assembly
Oil change with new filter
New battery with J-Bolts & Battery tender connector
New fluids in the transfer case and transmission
New genuine Land Rover heater box with new heater controls and cables
New Rear wheel bearings and hubs with new inner and outer seals
Rear differential flushed with fresh fluid
New stainless braided brake lines
New complete swivel ball kit with new front hubs,bearings,seals,bushings
New HD front and rear steering arms with HD units, wheel alignment
New HD steering rod set
New front brake pads and rotors with pins and OEM shim kit
New rear brake shoes with hardware kit and parking brake adjustment
New rear sway bar end links and bushings
New (6) Bearmach HD Shock absorber with Bearmach HD steering stabalizer
Interior:
New door cards
New front windscreen
New rear sliding glass
New rear corner glass (2)
New dash top pad with coin holder
New Dash insert bezel (black)
New Speedometer in MPH, GPS controlled (Rovers North Kit)
New Raptor UK Metal dash gauge bezel (powder coated black)
New upper steering wheel shroud
New lower steering wheel shroud
New headlight switch
New directional switch
New rear fog light switch
New ignition switch
New Series Defender Center 12V cover, stainless powedercoated black
New fuse box cover with new knobs and decal
New insulator pad for LT77 gear lever selector
New Aluminum heater and vent control knobs
New gear selector and transfer case lever knobs
New interior boot kit for LT77 for gear selector knob and transfer knob
New EXMOOR TRIM molded matting system for LT77
New seat cushions
New seat covers EXMOOR TRIM (grey) Driver/passenger/center seat
New under seat box aluminum covers
Exterior/Body:
New Hood
New front grill
New roof
New doors
New weather seals on doors,windscreen,windows
New finisher wingtop grills L/R and intake
New HELLA glass headlights
New directional and marker lights front and rear
New front bumper with stainless hardware upgrade kit
New Land rover badging front and rear
New tailgate stays
New tailgate stainless hardware
New Rovers North Class III trailer hitch with cover
New OEM spare tire holder
New (5) White WOLF HD wheels with new BFG K02 LT 265/75/R16
New raptor coatings bedliner
The truck was completely taken apart for a panel off restoration. The body work was done right, no cutting corners on this project. Once the body work was completed the truck was sent to Authorized Imported Cars in Flemington NJ (Land Rover restoration specialist) for all mechanical repairs. Over $22,000 in receipts for parts and mechanical repair. I spared no expense building this truck. The truck is very well sorted and is turn key ready.
