1 - 4 of 4 Posts
All,
Selling my 1987 D90. Too many projects so she sadly has to go.
Asking $26,000
Mileage: 195,000km on body
: 500 miles on new 200tdi
-Originally from Italy and has a painted chassis and bottom so zero rust.
Work done within the last 500 miles:
- Personally removed the 2.5TD and swapped with a 200tdi base with a 300tdi top end (cylinders and injectors) built by Zak at zombie motors in Salem. Now has 500 miles on it so it is barely used.
-Added power steering
-Brand new Firestone transforce AT2 tires (500 miles)
-New flywheel
-New pressure plate
-New Clutch
-New clutch master cylinder upgrade with stainless steel tubing
-New clutch slave cylinder.
-New brake switch
-New brake lights
-New door locks on the drivers side and rear door.
-New electronic fan (ford Taurus fan high CFM) with relays
  • New high torque gear reduction starter from Classic Car Performance. Starts her up with barely a bump of the key.
  • New Battery
The issues:
-Small chip in the windshield. Fixed with resin and no issues so far
-Needs new oil cooler return seal as there is a small oil leak if she sits
- The temperature reads hot even if she has been running for only a few minutes. Getting a new temp sender and will replace prior to sale.
-No rear seats or sound deadening in the load area.
Please message me for more details if there’s anything I’ve missed. She's completely mechanically sound and shouldn't need a thing in the engine bay (aside from dealing with some leaks).
1 - 4 of 4 Posts
