1 - 4 of 4 Posts
I am headed down to MAR with Randy at the end of the month and figured I would put this up here if anyone is interested. We could deliver it to MAR if you like.
Asking $14500 and as much of Randy's ribs as you can eat!!
Titled in PA. Right Hand Drive, fitted with a 2.5 diesel.
It starts easily and shifts well. It has 82183 miles on the odometer (converted from km's)
The engine was rebuilt in 2010.
Body panels are mostly straight, usual military NATO paintjob. Front seats and rear bench seats in very good shape, no significant rips or blemishes.
Newer canvas,it does not leak!
New wipers, drive belt and air cleaner fitted. Oil just changed.
Everything electrical works as it should.
Wolf rims and Michelen XZL's on all five. (tires in great shape, lots of tread left)
The bulkhead and footwells are also in great shape, there is some surface rust on the drivers footwell.
The frame and rear crossmember are perfect and have never been patched. There is surface rust on the frame that can easily be wire brushed before coating it.
The door bottoms are also good, there are two small holes in the bottom of the drivers door.
Cheers,
Neil.
1 - 4 of 4 Posts
