Seller's description
ASKING $29,500 OR BEST OFFER Defender was originally located in Australia 3.9L Rover V8, good runner pulled form Disco 1 (1995) to transplant to 110. |
OME 2” Suspension Lift |
Holley 4 Barrel Carb |
Noico 80 mil Sound Dampener |
Thermwell FV516 Frost King Foam and Foil Insulation Duct Tape 1/8” |
Proline 157SA Ignition Switch |
Champion New Battery |
Blue Sea Dual Battery Switch |
Rovers North Winch Bumper with LED Lights |
Stainless Steel Recover Points |
Rovers North Tree Sliders |
Rear Step Bumper with Rubberized Tread |
New Rear Door Card |
New Front Door Cards |
Reupholstered Headliner |
EDB 17301 Fuel Pump |
RV8 Gasket Conversion Set |
Brake Pad Spring and Pin Kit |
Ferodo Brake Pads for Defender 110 Front Disc |
Oil Seal Hub Bearing |
Master Cylinder |
Left Rear Wheel Cylinder - 110 |
Right Rear Brake Cylinder - 110 |
Crankshaft Sprocket RV8 |
Hub Bearing |
A/C Compressor Bracket Rover V8 V-Belt |
A/C Condensor Fan - SPALL (Open Box) |
Austin A/C Rebuilders Tab (Condenser, Custom Lines, Dryer, Pressure switch, all fittings, seals, new compressor) |
Bottom Hose RV8 |
Brake Disc Xdrill and Grooved 110 Front |
Brake Show Spring |
Brake system fill/flush/bleed |
Bypass Hose |
Condenser. Vacuum down system. Fill system with oil and refrigerant. |
Fluid Service |
Goodridge Brake Hose Kit - Stainless Steel Braided Front |
Install new Lines, Compressor, Dryer, Pressure Switch, |
Labor 10 Engine reseal - Comp'd as a new engine is going in to this |
Labor 21.58 Diagnose AC System, find all missing components and open |
Labor 8 Brake rebuild (Pads, Discs, Rotors, seals all the way around, |
Mintex Rear Brake Shoe Pair - 110 Drum |
Oil Seal Inner Hub Bearing |
Oil/Engine flush treatment, 2x volumes of engine oil, 2x filter R134A Refrigerant |
Rear Brake Drum 110 |
Replacement hardware (Bolts, studs, washers, nylock nuts, nuts, locktite) Floor dry, solvents, brake clean, rags, wiring, wire terminals, solder, relays, fuse holders |
Return Spring - Brake Drum 110 Rear |
RPI Engineering Thermostat Housing for RV8 4bbl conv. |
RPI Housing |
Top Hose RV8 3.5L Defender |
2x air breathers for valve covers |
A/C system oil and R134a recharge refrigerant |
Connecting Rod Bearings Rover v8 |
EFI Fuel pump, 60PSI, In-line w/ barb fittings mount for fuel pump |
EFI rated fuel filter, in-line with barb |
EFI rated fuel hose |
Engo 9000lb winch w/ wiring and fairlead |
head studs - ARP - Rover v8 |
hose clamps |
Hydraulic Lifter - RV8 - Genuine |
Kent "180 grind" performance cam |
Main Bearings - 3.5/3.9/4.2L Rover v8 |
Mount for fuel filter |
RV8 Hydraulic Lifter |
V8 Reseal Kit (top end and bottom end, all seals and gaskets) |
Defender Clutch Master |
Clutch Hose |
Manual Gearbox Clutch Slave Cylinder |
Sony Radio bluetooth |
