41 - 60 of 63 Posts
· Registered
My stock rebuilt 2.5 and stock carb with 1.4 gearing will get up to 65 no problem and will continue to accelerate past 70. This is in a 90 but to be honest it may be faster than the 200tdi I had in a previous defender. Quiet smooth engine.
· Registered
1985 Ninety R2.8
Discussion Starter · #43 ·
Appreciate that. Unfortunately I HAD a 1.4 in my 90 before I changed it all… but I also moved shortly after, and gave the 1.4 and LT77 away to my mechanic (I just needed it out of the garage). I’m kicking myself now.
· Registered
1985 Ninety R2.8
Discussion Starter · #45 ·
Getting there!
I had this little plaque made over the Christmas break. I checked with Roland at ACR and he was fine with me using his logo. If it ever actually turns over, Ill find a place to fix it in the engine bay:
· Registered
1985 Ninety R2.8
Discussion Starter · #46 ·
I'm also officially half way done the rear axle rebuild:
Stripped it down, used Eastwood Rust Encapsulator, then a top coating of Eastwood Chassis Black.
In hindsight I wish I didn't open the differential, but I at least got to learn about backlash and gear wear patterns. Both of which are good.
New Stub axles, Timken bearings, and end float all set up. This axle only has an inner seal (replaced).
I kept the previous brake shoes (they are clean and still have good pads).
(Please excuse the mess - it is a character flaw)
Next up is the other side of the axle. Im putting together an order now for springs, bushings, bolts, everything needed to flip the chassis down, and get this rear axle underneath.
I might skip out on the front axle for now... just to keep the project moving ahead. With the motor done, I'd love to mount the lump back in... at least make it feel like I am progressing.
Thanks for reading,
Dave
· Premium Member
Getting there!
Why not on the top of the valve cover?
· Registered
1985 Ninety R2.8
Discussion Starter · #50 ·
It is early in the morning and I might not be seeing correctly, but you might have both leading shoes on one side and both trailing on the other. Worth checking.
Thanks VERY much. I just put them back on the same way they came off (but who knows if that was correct). Both shoes looked identical to me, so I figured maybe leading/trailing wasn’t a thing anymore🤦🏼‍♂️
Really appreciate it, I’ll check when I get home tonight and report back
· Super Moderator
The only difference in the shoes (that you buy these days) is the location of the adjuster pin. The friction material location is the same. If you get them in wrong, then the adjusters don't work correctly.
· Registered
1985 Ninety R2.8
Discussion Starter · #52 ·
Amazing! You rock.
I zoomed in on the other side that is laying on the floor in my picture.
You’re spot on, the distance from the spring to the adjuster pin is different. Whomever put them on before was incorrect.
· Registered
1985 Ninety R2.8
Discussion Starter · #53 ·
Sorted the brakes out…
but the plot thickens. As it turns out the backing plate has a leading and trailing side as well (the adjusters are positioned differently- which clearly makes sense in retrospect).
I had the backing plate on the incorrect side… so that had to be changed as well.
Thanks again Red90, now It’s back together correctly! (I think)
(I still have to bend down the lock washer, but I’m waiting until the other side is complete. I went through 3 washers figuring out the backing plate!)
· Premium Member
Excellent.
Was thinking on the same thing, but wasn't sure if the shoes were not symmetrical, but then...
DJW, you might want to consider how to send Red90 a bottle of Scotch IMHO.
Reactions: DJW
· Premium Member
Amazing eye. Would never have looked for that. I second the scotch.
· Registered
1985 Ninety R2.8
Discussion Starter · #57 ·
On the topic of “do I need to re do this Salisbury rear differential?”…
Thanks again to Red90, the rear axle is nearly complete (a new hub washer coming from RN and it’s done).
So I moved over to reseal the pinion oil seal. Read a lot about them, so much infact, I neglected to read about marking the bolt and flange before removing them… so you can be sure to set the bearing preload correctly on reinstall 🤦🏼‍♂️
I put in the Dana 60 seal, but would appreciate anyone’s opinion on if my flange is scored too much, and either needs replacing, or a Speedy sleeve?
And, of course, can I simply replace the flange nut, tighten it and hope everything will be ok (I’ve searched, and haven’t been able to find a direct answer). Or is it diff out, new crush washer, shims, and set it all per the book?
As always, greatly appreciated.
· Registered
1985 Ninety R2.8
Discussion Starter · #59 ·
Rolling Chassis!
I still have to sort out the front brake calipers and discs (and learn all about them)… so I skipped ahead to getting myself a rolling chassis.
This makes the project feel miles ahead. Figuring out how to move the chassis single handedly was the best part 🫣
41 - 60 of 63 Posts
