1 - 11 of 11 Posts
I need to replace my 12v (lighter) socket, and want to put a USB socket in as well while I'm at it. So, I'll have both a round 12v socket and a separate hardwired USB socket. I'm thinking of https://www.amazon.ca/gp/product/B07PZZ9C3N for the USB socket. They claim over-voltage, over-load, over-heat, and short-circuit protection but that doesn't mean a whole lot.
With these ports being used to power more complex and expensive electronics, is it OK to just go to Amazon or wherever and buy a USB socket like that, and a generic lighter adapter and wire them in? Or, is it smart to get something better/safer? If so, what do you recommend?
Thanks,
- Andrew.
You might as well get one with 2 USB sockets.
Or get a flush mount one that plugs into a 12V outlet. Like this one, from a well respected brand. https://www.amazon.ca/Charger-Anker-PowerDrive-Adapter-iPhone/dp/B07PGT7LSR/ref=sr_1_7?keywords=dual+usb+anker&qid=1576108315&s=electronics&sr=1-7
Personally, I like Blue Sea https://www.amazon.com/Blue-Sea-Systems-Charge-Charger/dp/B01BV1MTAA/ref=mp_s_a_1_fkmr1_1?dchild=1&keywords=bluesea+usb+plug&qid=1576109129&sr=8-1-fkmr1
And definitely prefer the double port.
When it comes to wiring and removing old ****, I prefer to buy the right thing the first time even if more expensive. Wire it once, do it right, and hope you never have to do it again.
The BlueSea idea seems like a good one, thanks. That's the sort of thing I was looking for, likely a step up from what I'd found so far.
I'd seen the double-port version of the product I'd originally posted, but as it has a built-in volt meter, I wanted to be able to shut that off when the vehicle's parked. So I decided that 1 USB port plus switch was a better option.
I could use something like the Anker adapter, but I'd rather put in a dedicated USB socket and a 12v socket vs. two 12v sockets. The USB-A socket can always be replaced later with a USB-C or whatever. Or use a USB-C adapter in the 12v socket at that point.
I generally recommend Blue sea just in terms of a name brand, plenty of cheaper alternatives but smartphones are expensive and I have seen a few crazy things with fast charge these days.
Begs the question. How high an amperage can most phones take on a quick charge ? Now there are 3's and 4.8's. Dont know enought enough about lithium batteries. Have been installing 2.0's in customer trucks.
"Quick Charge" does not use more current. It increases the voltage to charge faster.
That article is out of date. Modern quick charging system increase the voltage beyond the traditional USB 5 volts in order to provide high charge rates.
If you want to charge quickly on a modern device, you really want to get a USB-C as it is standardized to allow the higher voltages. QC3 does increase voltages with a traditional USB port, but this is outside of the USB standard. Getting a port with a USB-PD designation is the safest bet to ensure proper compatibility with you modern device.
1 - 11 of 11 Posts
