Mercedes OM617 Power Steering Pump - Seal Replacements
So need to catch up on the last week or two of progress...
Power Steering Pump Seal Replacement
I ordered a 4 bolt Land Rover power steering box a few days ago off a forum member so I figured I may as well take a stab at getting the pump ready.
Tools
- 13 mm socket
- 21 mm socket
- 22 mm socket
- 30 mm socket
- 13 mm wrench
- Impact
- Ratchet
- Deadblow(s)
- Pick
- Couple Flat Head Screwdrivers
- C-Clamp or Similar
- Pulley puller (ideally) in my case I got away with a pit-man arm puller and a washer
Parts
- 000-586-52-46 Power Steering Pump Dichtungspartner Hamburg Gasket Set (or similar)
- 018-997-60-47 Mercedes Power Steering Pump Shaft Seal
1. Go locate 2nd engine block with ancillaries.
2. Cut slit in shrink wrap
3. Locate power steering pump.
4. Three bolts hold the pump in place. They come off quick if you can get an impact with a 13 mm socket and wrench on them.
5. Note that there is also a bolt with a plastic injection molded nut locator on the end. This is needed as well as it help adjust the power steering belt tension before tightening the main bolts.
6. Scrub 90% of the crap off with a brush, oven cleaner, and simple green.
7. Once clean(er) zip the pulley nut off using a 22 mm impact socket. In my case I was able to just hold the pulley by hand and let rip some ugga duggas.
8. Once the nut and washer is removed if you are:
- Super Lucky: The pulley will fall right off
- Lucky: You can have a help lift the unit up by the pulley about 1" off the table and give a
few deadblow whacks and it will come off.
- Normal: Grab a pulley puller and take it off that way.
Or you can be a peasant like me and realize your puller wasn't quite large enough in diameter....
It turns out though that some pitman arm pullers juuuuuust barely slips over, enough that you can put the nut back on, use a washer to spread out the offset load, apply tension, and with a good side shock from the deadblow the pulley falls right off.
Pulley is off, and there is still a bit of crud in here to get out. A leak was very possible.
9. On the back side of the unit there is a big metal spring loaded plug sealed with an O-ring all head in by a steel clip.Making sure the nut is threaded back on to the shaft to protect the threads you can apply a slight force to a large C-clamp (or quick grip and a spacer).
