VDO Oil Temp Gauge Help - Defender Source
Old October 7th, 2019, 08:25 PM
mdubs's Avatar
mdubs
Matt
1986 Tithonus Defender 110 ST
Would like some help/advice on hooking up the installed VDO Oil Temp gauge. Gauge is not functioning because I didn't have the correct sender when the gauge swap happened. It does have power for the gauge backlighting when I turn on the headlights (which also aren't working, but that's a different issue...), but has no temp indications.
I saw this video that recommends using an adapter on the oil sump plug to get the temp reading and then wiring it to the gauge.
I was looking for an oil sump adapter and took some pictures of my oil sump and I have 2 plugs, one of which has wires coming out of it. I also have a working Oil temp pressure gauge that has a wired coming off of the sender, but I think that is supposed to go to my oil px light in the binnacle. I'm pretty sure that light does not work either. I bought what I thought is the correct temp sender but I'm not sure if I need to get one of the sump plugs drilled, if I can used the existing wires, or if I need a special adapter.
As you can tell I'm kind of lost and need a little guidance. Ideally I'd like to get the Oil Temp VDO gauge and the Oil Px light binnacle light working. I can take pictures of the back of the gauge tomorrow if that will help me diagnose. Thanks in advance.
ID:	430802   Click image for larger version
Old October 7th, 2019, 08:27 PM
mdubs's Avatar
mdubs
Matt
More pics of Oil Px sender and oil px light wire (I think)
ID:	430810   Click image for larger version
Old October 7th, 2019, 08:28 PM
mdubs's Avatar
mdubs
Matt
Correct VDO sender? Do I need this?
Old October 7th, 2019, 08:46 PM
What engine?
Condensation leads to rust, Rust leads to anger, Anger leads to hate, Hate leads to suffering.
Old October 7th, 2019, 08:47 PM
mdubs's Avatar
mdubs
Matt
3.5 v8 with 14CUX EFi
Old October 7th, 2019, 09:06 PM
Those engines have a port on the oil filter housing for an oil temperature transmitter. I'm not sure the thread size. Best to pull the plug and measure.
They also have a port for an oil pressure sender, so there was no point in using the tee fitting.
Old October 7th, 2019, 09:20 PM
Pretty sure this is right. Best I can find the oil temp port is 9/16" UNF (weird size), but LR make a 5/8" UNF adapter, part number 611514. Best to check the threads yourself though.
Old October 7th, 2019, 09:21 PM
mdubs's Avatar
mdubs
Matt
Thanks John! Iíll look tomorrow.
Old October 7th, 2019, 09:30 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
the unit on the sump is a oil level switch? AFU2786?
I take your Px means pressure?
I voted to leave the EU, not a deal.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 2hundie 5 speed (for sale)
05 D3 HSE
97 XK8 BRG FHC SOLD
94 RRC County swb
Old October 8th, 2019, 06:27 AM
mdubs's Avatar
mdubs
Matt
Yes sorry. Px is Pilot talk for pressure. Still not sure what the wires coming out of the oil tank are...
Old October 8th, 2019, 07:27 AM
Builder of custom Defenders
Your engine is from an early range rover that had an oil level warning light, that's what is in the side of the sump. This was deleted on later trucks.Senders are matched to gauges. You need to figure out where you wish to take a temp reading be it @ the filter head or @ the sump. You then need to look @ which sending units work with the gauge you have bought ( they vary by different resistance ranges) and what size and thread pitches are available and you then need to obtain an adapter to go from the thread of the aperture you have chosen down to the thread of one of the available sender's that works with your gauge.
If your oil pressure light is not working try removing the signal wire from the sensor and ground it to a bare metal surface on the engine, light should be on, if not suspect the bulb has expired or has corrosion. If the bulb illuminates your sender is bad. The sender is a pressure on off switch that switches ground to the lamp.
Your convoy light switch was worn out, erratic. If it hasn't been replaced, it needs to be.
Old October 8th, 2019, 08:03 PM
mdubs's Avatar
mdubs
Matt
Thanks for the info Doug. I guess I’ll be starting a Wanted thread for a convoy switch!
Old October 8th, 2019, 09:35 PM
Random/dumb question.... why oil temp in a 3.5? I would be way more concerned with coolant temp, and oil pressure.. just me though... oil temp is a function of overall block temp... this coolant is more important and what kills engines. That is the first gauge I would replace with a VDO.
These engines donít have a lot of oil pressure which is important so I just did a gauge for that (and now have 2 coolant temp gauges (sniper is one)
95' D90
92í D110 - ZA
Old October 9th, 2019, 06:37 AM
mdubs's Avatar
mdubs
Matt
I have coolant along with oil px, oil temp, rpm, fuel, speedo & voltage. Oil temp is the only one that isn’t working. I know I don’t really need it as I don’t tow anything, but it’s slightly annoying to have it installed but inop.
I’d eventually like to get one of these coolant lights as well.
https://youtu.be/OHfD-BNPVcg
ID:	430988   Click image for larger version
Old October 9th, 2019, 11:38 AM
Iíd replace it with a voltage gauge or a clock.
95' D90
92í D110 - ZA
Old October 9th, 2019, 01:00 PM
mdubs's Avatar
mdubs
Matt
I have a voltage gauge on the far left. Plan for the middle of the Mud UK console is to get a large 8-Day vintage aviation clock made by Breitling and stick it in there. I saw Bo had a little one in his 110 and I got clock envy.... You know what they say about Pilots and big watches...
Something like this:
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
