Uh...not seeing the point of a snorkel.... - Defender Source
Old July 16th, 2019, 03:24 PM
s0reye
Bryce
2011 LR4
Th pervious owner put a snorkel on. I've changed the air filter a few times but the other day was the first time noticing a factory-made hole in the bottom of the air filter housing (2.5TD). Does anyone have any recommendations to plug this up? Or is there an aftermarket housing I should be looking at?
Reference pic below.
Old July 16th, 2019, 03:32 PM
Z.G's Avatar
Z.G
Zack
322 + $1.10 project
Every air filter housing has a drain(for the most part). Most of them aren't that large though. Looks like you're missing NTC3751, which unfortunately isn't available from LR any longer. There may be alternatives though
Old July 16th, 2019, 08:52 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Round piece of plastic and some silicone? Body plug and some silicone?
Old July 16th, 2019, 09:24 PM
Z.G's Avatar
Z.G
Zack
322 + $1.10 project
Something close should work, but you want it to be able to drain at least a little
Old July 16th, 2019, 09:48 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
Powered By Chevy 292 (4.8L) EFI
Water does not compress when inside an internal combustion engine.
Your best option is to leave the hole open to the atmosphere to drain water from the inlet charge of the engine.
If you become more obsessed with the opening put some sort of screen underneath the opening to make you feel more secure, but leave it open to the atmosphere.
If the hole was whole it wouldn't be a hole and thus never needed, but it is needed, so best left alone to be hole.
Do NOT FOLLOW THIS ADVICE!
Again leave the hole alone, like it is a power that is not understood, but a requirement for a healthy existence.
RDavisinVA
Old July 17th, 2019, 12:01 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
Some people think they look cool(?)
I've also heard folks say they help in dusty driving by putting the air inlet up high.
But few rigs are set up for deep wading (diesel, no or waterproofed electrics, etc).
If you really want to plug the hole, maybe with some sort of 1-way check valve that lets water drain, but not back in.
Old July 17th, 2019, 07:27 AM
FlyersFan76
1987 110 Convertible
That hole is to let water out in the event that water gets in. With no snorkel water will get in.
There is probably a rubber duck bill grommet so that only water goes out and not in.
1987 Land Rover 110 Convertible
2017 Range Rover Sport
1997 Defender 90- AA Yellow #1701- Wrecked
1997 Defender 90- AA Yellow #?- Sold
2000 AM General Hummer- Sold
Old July 17th, 2019, 07:37 AM
Z.G's Avatar
Z.G
Zack
322 + $1.10 project
Correct. The part I referenced earlier looks like this
Old July 17th, 2019, 08:28 AM
KGH's Avatar
KGH
Real Name
'13 110SW,'87 127,’85 110PU...
Holy cow, I wholly agree.
KGH - “Stinky LR diesel” Defender Snob
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
