Stub Axle Bronze Bushing/Half Shaft - Defender Source
Old June 23rd, 2019, 10:27 AM
Joatman66
I am in the process of rebuilding/replacing swivels, wheel bearing, brakes, etc.
I went through the LH side without much issue. On the RH side, it seems the bronze bushing is extremely tight against the half axle making it very hard to free spin without much outward movement. I barely had enough play to get a thin shim and C-Clip on it.
First time for me doing this work. Will this ease up over time of is it somethig I need to address before driving?
On another note, what keeps the rear axle from sliding out? C-Clip limits inward movement, but is there something keeping from moving outward?
Old June 23rd, 2019, 10:40 AM
The CV should be a loose fit in the bush, not tight.
The shaft shaft can't come though the drive member on the rear as the splines won't let it.
Condensation leads to rust, Rust leads to anger, Anger leads to hate, Hate leads to suffering.
Old June 23rd, 2019, 10:47 AM
Joatman66
What would cause the binding? New stub axle and new bushing...
Could I have squashed bushing installing it? I thought I was kind if gentle installing it.
Old June 23rd, 2019, 11:22 AM
Builder of custom Defenders
If you can get the c clip on, run it with no shim and check it again in a few hundred miles. Shims are meant to limit inward travel. With a
new stub axle etc I'd drive it a bit. The depth of the cut splines against the hub limit outward travel.
Old June 23rd, 2019, 12:21 PM
Joatman66
I like that idea a whole lot more than swapping parts. I have a bit more work before itís back in the road but will try your advice.
Thanks!
Sent from my iPhone using Tapatalk Pro
Old June 23rd, 2019, 02:48 PM
Where did the bushing come from?
Old June 23rd, 2019, 03:12 PM
Joatman66
Kit came from Paddock Spares - https://www.paddockspares.com/stub-a...-up-to-ka.html
Old June 23rd, 2019, 09:18 PM
Naplm00
M
Replaced my fronts with a kit very similar to this I had to make sure that that bronze bushing was 100% seated into the stub axle. The brand new CV was also a very snug fit. But it snapped into place with a light tap of the hammer
Originally Posted by Rover4x4
I've been rear ended by an fj40 running 50+ as a passenger in a Cherokee, the tool box was in front of the truck. I've been there bruh. Yeah.
Old June 24th, 2019, 07:42 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Funny seeing a post on this issue. Thank you for the help Saturday with this.
Old June 24th, 2019, 08:39 AM
Naplm00
M
I know right ? No prob
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
