Help! 200TDI Radiator Installation - Defender Source
Old June 18th, 2019, 11:20 PM
edemusmaximus
Ed O
1990 Defender 90 200tdi
This is on a 1992 130. Removed the old radiator, installed the new radiator from Paddock. I made sure to look at the oil intercooler lines/fittings to make sure they looked the same, and they did. Installed the new radiator tonight, turned it on, and oil was spurting all over the place. Could I have missed something? I believe I tightened it down well enough. I am a little afraid that I missed something on the oil couplings and that the one from the previous radiator was slightly different from the one on the new radiator. I could use some guidance here...not really sure where to go from here...
Old June 18th, 2019, 11:25 PM
Various
Mendicant
Pix please.
Old June 19th, 2019, 06:30 AM
Builder of custom Defenders
There are two types of radiator to oil line fittings. One type uses o rings the other is a flare type connection.
You will likely need to unscrew the fittings from your old radiator and swap them to the new one so they match up.
Old June 19th, 2019, 08:43 AM
edemusmaximus
Ed O
Pix. Sent post last night under the stress of doing last minute work on truck before bed and day before movers got to the house. Movers here....do I need a different hose for the fitting that is on this radiator? I thought it looked the same as the previous one.
ID:	421252   Click image for larger version
Old June 19th, 2019, 08:55 AM
Yeh the fittings on the new rad are the O-ring type (like air conditioner fittings) and the hoses you have are clearly flare. Either take the adapters off the old rad and put them on the new rad or get new hoses with compatible ends.
1965 2A 88
1971 RRC
1989 RRC
Old June 19th, 2019, 08:56 AM
edemusmaximus
Ed O
The workshop manual did not mention any rubber ring or using a thread sealant...didn’t notice one in previous radiator...am I missing those part or methodology in order to achieve a tight seal?
Old June 19th, 2019, 08:58 AM
edemusmaximus
Ed O
Smh. Old radiator trashed. Do you know if the old coupling fittings can be ordered? Is the better route to change the oil lines?
Old June 19th, 2019, 10:53 AM
edemusmaximus
Ed O
Bought two new NTC3858 couplings that should do the trick. Appreciate your comments!
Naplm00
M
You can order the fittings , Trevor at rovahfarm has em .
For now to get you so you can move the truck loop a rubber hose from line to line and clamp it . I wouldn't drive it far like this tho in hot weather
Originally Posted by Rover4x4
I've been rear ended by an fj40 running 50+ as a passenger in a Cherokee, the tool box was in front of the truck. I've been there bruh. Yeah.
Old June 19th, 2019, 11:17 AM
edemusmaximus
Ed O
Trevor is on a well deserved hiking trip in the Maine woods...tried calling but he’s still away! Happy for him though. Was able to source the parts from somewhere else that had them priced well and could get them out to me quick.
Old June 20th, 2019, 10:26 AM
edemusmaximus
Ed O
Got my new couplings. Previous couplings did not have thread sealant/tape. Should they. Apply them to the new ones?
Old June 20th, 2019, 12:24 PM
Naplm00
M
wont hurt
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
