Electrical Fire - Page 2 - Defender Source
Old April 1st, 2019, 07:44 AM
If it's me, I would like to know why this happened and, further, why the fuse did not pop to protect the wires. If you just replace the damage without learning the cause you're in for it again.
1965 2A 88
1971 RRC
1989 RRC
Old April 1st, 2019, 10:37 AM
User Name
User
NAS D90 '95
This is a great point. Itís rare to see internal wiring breakdown the same way as the external segments. Meaning, it wouldnít be my first guess to look for frayed wiring.
My next thought would be a mechanical connection. In that location, there arenít many mechanical wire crimps, two major ones, the constant unfused brown and the switched unfused white; both connecting to the ignition switch and both with mechanical crimps within inches of the switch - maybe one broke but, I doubt it. Looking at the pictures, the damage is heaviest at the ignition switch, I also see some aftermarket wiring and inline fusing in the background, one may surmise that a tap was made into either the brown or white wire and it was right at the mechanical crimps at the ignition switch.
The unfused nature of those wires could account for why a fuse didnít blow. Technically, the brown is used with a maxi in the engine bay but there are many reasons for it not blowing in time. The white is completely unfused.
Old April 1st, 2019, 10:52 AM
seriessearcher
Sean
1971 Series IIA Dormobile
When it comes to electrical and your Defender, the shop rate may be good insurance. Have you checked with https://www.roadsidewerx.com/?
As Bill stated, if you just replace and not correct you may just see the same or worse happen again.
Old April 1st, 2019, 03:24 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Looks like most of the damage is at the igition switch?
The harness I have does need some new wires run in (white). I got this loom with a bulkhead so it has not been used by me.
Would also be the time to add blade fuse holders. Your call
ID:	414824   Click image for larger version
ID:	414828   Click image for larger version
I voted to leave the EU, not a deal.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 2hundie 5 speed (for sale)
05 D3 HSE
97 XK8 BRG FHC SOLD
94 RRC County swb
Old April 1st, 2019, 04:49 PM
User Name
User
NAS D90 '95
Yes, from the pictures it looks like most of the damage in vicinity of the switch.
Old April 2nd, 2019, 12:13 PM
LRColorado
1990 Defender (200 TDI)
Source of problem
Yes, I also believe it was the ignition switch. I was moving the heat vent control arm from feet to windscreen and within 60 seconds smoke started seeping through the windscreen defrost vents.
Old April 2nd, 2019, 12:36 PM
roverman2010
1985 LR 90 200Tdi
John, send me a pm (not a visitor message as it seems to be read only once? And lost it) with your address I will send you what I got and if you can use it we can figure out later value. If you can't use it you only pay shipping both ways. Fair dinkum.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
05 D3 HSE
97 XK8 BRG FHC SOLD
94 RRC County swb
Old April 3rd, 2019, 08:03 PM
LRColorado
Really appreciate all the advice and help!!!
Old April 10th, 2019, 04:44 PM
Roverlab
Trevor Griffiths
92 110, 92 RR, 14 LR4
I'd also suggest that if you have any concerns about the instruments being damaged, might want to consider VDO Vision Black gauges. Actual numbers instead of vague bar graphs, and they even have the tachometer.
Email is
Same place, new dogs.
Old May 4th, 2019, 11:14 AM
User Name
User
NAS D90 '95
What ever came of this?
Old May 4th, 2019, 11:19 AM
roverman2010
1985 LR 90 200Tdi
Ditto
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
05 D3 HSE
97 XK8 BRG FHC SOLD
94 RRC County swb
Old May 14th, 2019, 11:00 AM
roverman2010
1985 LR 90 200Tdi
What ever happened to this guy? Sent a harness to him but not heard a dicky bird
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
05 D3 HSE
97 XK8 BRG FHC SOLD
94 RRC County swb
Old May 14th, 2019, 01:43 PM
User Name
User
NAS D90 '95
For free?
Old May 14th, 2019, 03:28 PM
roverman2010
1985 LR 90 200Tdi
Nope!!
For free?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
05 D3 HSE
97 XK8 BRG FHC SOLD
94 RRC County swb
Old May 14th, 2019, 03:34 PM
Vedrover
Alex
1988 Land Rover 110
He got electrocuted?
From another forum on "what killed the British auto industry":
- "I'm pretty sure it was Joseph Lucas."
- "Ah, The Prince of Darkness with his three position switch: "off, flicker and dim"."
Old June 20th, 2019, 10:53 AM
roverman2010
1985 LR 90 200Tdi
Has this been fixed? Anybody know this guy?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
05 D3 HSE
97 XK8 BRG FHC SOLD
94 RRC County swb
electrical fire
Tdi electrical diagram artm Defender Technical Discussions 2 January 13th, 2006 08:52 PM
Yet another engine fire chrisvonc Misc. Chit-Chat 80 August 30th, 2005 02:22 PM
Fire Extigushers rover4x4 Defender Technical Discussions 20 March 18th, 2005 12:24 PM
Electrical for beginners paulb Defender Technical Discussions 5 October 18th, 2004 01:58 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
