D110 Right pull when braking - Defender Source
Old October 15th, 2019, 06:27 PM
crystalclear
Richard Lee
99 d2
above 40/50mph when needing to stop a tad bit more in a hurry, i get a nice semi-lane change to the right
checked left side brakes - swapped out the caliper/rotor/pads as the calipers were kind of sticking and the pads looked warped
right pull still kind of there
front radius arms and trailing arm bushings all seem fine
what else should i look for here? i assumed the brake lines going to the left were fine as when i bled the new stuff, flow seemed normal to me
Old October 15th, 2019, 07:03 PM
Builder of custom Defenders
Any of your metal brake lines pinched ?
Old October 15th, 2019, 07:38 PM
crystalclear
Richard Lee
99 d2
havent followed the line from the mc to the left side but will do so later
Old October 17th, 2019, 04:54 PM
crystalclear
Richard Lee
99 d2
ok....after inspecting brake lines and rebleeding - i am leaning towards something in the front suspension/steering
the rightward pull happens on sudden heavy pressure braking.
what would be the culprits here? im guessing right side components
Old October 17th, 2019, 05:42 PM
crystalclear
Richard Lee
99 d2
let me also ask - how much play should there be on the steering box drop arm ball joint / adjoining tie rod?
i can grab the steering damper and fairly easily rock the assembly back and forth
could this cause my brake pull....
im even beginning to think previous owner put a mismatched set of front springs on
Old October 18th, 2019, 12:06 PM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
Check wheel bearing clearance
Old October 18th, 2019, 12:12 PM
crystalclear
Richard Lee
99 d2
would wheel bearing clearance be an issue on the side it is pulling towards (the right side)?
and what exactly do you mean by wheel bearing clearance?
Old October 18th, 2019, 12:52 PM
headdamage's Avatar
headdamage
Andrew
Exmil 90 & 110, RRC 200tdi
Have you checked tire pressure?
Old October 18th, 2019, 02:21 PM
There should be zero play in any of the ball joints. With a properly setup steering system the only play at the steering wheel will be the flexure of the tires. You need to go over everything, steering box play, steering box bolts, steering shaft u-joints, all tie rod ends, panhard rod bushings and bolts, swivel bearing preload, hub bearing preload, alignment, all suspension bushings.
Condensation leads to rust, Rust leads to anger, Anger leads to hate, Hate leads to suffering.
Old October 18th, 2019, 04:11 PM
crystalclear
Richard Lee
99 d2
tire pressure good
addressing all steering components......on it
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
