clutch replacement help - Page 2 - Defender Source
Old March 28th, 2019, 05:59 AM
Kdawg97m3
Kristian
1994 D90
Thank you! On it,,
Old March 28th, 2019, 09:04 AM
gwmckee
George
1994 NAS D90 #1919
Originally Posted by Kdawg97m3 View Post
Thank you! On it,,
You may also want to check the clutch fork. There have been instances where they fail. It could be that your master, slave and disc are all fine and the fork just gave up the ghost. I think you can remove the slave cylinder (two bolts) and look in the hole to see if the post on the slave pushed through the fork. This would, in the end, require you to separate the engine and transmission in order to repair.
Old March 29th, 2019, 03:58 PM
Muleskinner
1991 Ex Mod Defender 90 2.5 l Diese
Clutch Slave and Master Cylinder replacement
I just replaced both. It took about three days, but that was because of some rust issues with the housing that holds the clutch master cylinder. I cleaned and painted housing then replaced master cylinder. I could probably do the job in less than a day, but I am 70 and I can not get under the vehicle as easily as I could at 40. The slave cylinder is in a tight place next to exhaust. You will need to move a heat shield that is on the exhaust. But that is not an issue. I attached a ten foot section of clear plastic tubing to the bleed value and drained the old fluid out. then filled the master cylinder with clean fluid. Applied suction to the clear tubing until I saw clean fluid. then secured the bleed value. Job completed. I like dealing with Trevor at Rovah North, he has all the parts you need. Reasonable price and good service.
I have an 1991 Ex MOD Defender 90, RHD with 2.5 L NA Diesel engine. You will need several extensions when removing the slave cylinder. The bottom bolt is removed from underneath the vehicle as well as the hydraulic fitting. The top bolt is removed from the top of the slave cylinder with a ratchet and a long extension (at least 12-14 inches)
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 07:01 PM
Imperial Fan Clutch replacement souza Defender Technical Discussions 11 August 19th, 2008 10:36 PM
Fan Clutch Replacement JMPDIV82 Defender Technical Discussions 8 December 27th, 2007 09:00 AM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 02:18 PM
Clutch spring MOD--MUST HAVE evilfij Defender Technical Discussions 2 July 3rd, 2005 09:03 PM
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
