Clutch question - Defender Source
Old October 22nd, 2019, 06:52 PM
koltonstanley's Avatar
koltonstanley
Kolton Stanley
defender 130 hi cap
Clutch question
quick question for you guys.
I just had my clutch rebuilt.
I picked up the truck after hours so i didnt have a chance to talk to mechanic yet.
I will go back tomorrow and talk to him just trying to have some info so i know what im talking about.
before rebuild all gears shifted perfectly.
only reason i did rebuild was because i was hearing the throwout bearing make noise and i was losing clutch fluid into transmission.
so i picked up truck today and
#1
the gear shifter doesn't return to center if you arent in gear.....there is like 2 halfs a left side and a right side if that makes sense. and you can push it to the left side or the right side without selecting a gear. also a pain while shifting to push it from side to side.
#2
its basically impossible to find 3rd gear.......sitting still i can find it sometimes but while driving almost impossible.
what causes these sort of issues? are they just adjustments or something bigger?
i have a newer durotorq engine with 6 speed mt82 transmission....
thanks!
Old October 22nd, 2019, 07:00 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
It sounds like the shifter needs adjusted. It takes about 10 mins to do it on a Defender. Not sure on your hybrid design.
Angus
Old October 22nd, 2019, 07:09 PM
koltonstanley
Kolton Stanley
defender 130 hi cap
ok so hopefully not a big deal.....just some adjustment........ fingers crossed...
Old October 23rd, 2019, 01:33 PM
#1
#2
thanks!
Sounds like the bias springs are messed up. Its an easy fix. look at the videos for slick shifts.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
