94 NAS 90 Dies when hot - Defender Source
Old April 24th, 2019, 12:57 PM
gwmckee
George
1994 NAS D90 #1919
Hey Guys - been struggling with this issue for a few weeks now. Truck starts on the first crank and runs great for about 15-20 minutes then just dies. I pulled the coil wire and there is no spark. Let it cool down for a bit and she fires right back up. So it seems like an ignition issue vs fuel. Thinking it was the coil, I put in a new bosche unit and get the same result. Put in a new ignition amplifier module and same result. My question is... what would kill the spark when the engine warms up?
I ran through the ignition preliminary checks in the manual and found this anomaly. Test 3 - Check Amplifier Switching. Manual says "connect the voltmeter between battery positive terminal and coil negative terminal: the voltmeter should register zero volts. Switch the ignition 'on' and crank the engine. The voltmeter reading should increase just above zero, in which case proceed with Test 5." With the key in the off position I am reading battery voltage. I do have an ignition amplifier module relocation kit in my rig if that matters.
Thanks in advance.
Old April 24th, 2019, 08:03 PM
User Name
User
NAS D90 '95
When the truck shuts off on its own is one of the battery terminals hot to the touch?
Old April 24th, 2019, 08:44 PM
gwmckee
George
1994 NAS D90 #1919
Haven’t thought to check that. I’ll be down at my shop this weekend and will get back to you. What will that tell me?
Old April 24th, 2019, 09:03 PM
cowboy
Some recent quality responses to a similar issue, tho the responses may have different per your no-spark-from-coil clue: https://www.defendersource.com/forum...post1919736248
Old April 24th, 2019, 09:23 PM
gwmckee
George
1994 NAS D90 #1919
Yep, I was following that thread closely but not sure it’s the same issue. For sure my truck loses the spark from the coil wire when it warms up and takes about 30 minutes of cooling down before it starts up again. I don’t think the other post ever discerned if the problem was fuel or spark. I’m thinking that the engine and fuel temp sensors aren’t in play here as this is spark and not fuel. I believe the efi system doesn’t manage spark. Makes total sense that the ignition amplifier module is failing but I swapped it out and got the same result. What else tells the coil to fire??
Old April 24th, 2019, 11:10 PM
cowboy
Doesn't the coil get it's instructions from a pulsated signal created by the distributor pickup? 25 yr old dizzy pickups: GUILTY until proven innocent!
Old April 24th, 2019, 11:44 PM
Davis's Avatar
Davis
Davis
94 NAS D90 6.2LS
I agree.
"buy once cry once" comes to mind ;)
Old April 25th, 2019, 12:08 AM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
I had similar issue issue when I had my 94 D90. It would start fine cold and would run fine for a while. When engine was warm, the engine would just cut off. After cooling down it ran normal. Lucky I was near Trevor Griffith’s shop. It turned out to be a bad O2 sensor.
Sent from my iPad using Tapatalk
Old April 25th, 2019, 12:13 AM
Davis's Avatar
Davis
Davis
94 NAS D90 6.2LS
Which brings up a good point— did you check for codes?
Old April 25th, 2019, 01:37 AM
Chris B
72 + D1 drivetrain =?
If it's good when cold probably no codes. As I mentioned in that other thread, replace the coil. BTDT. At worse you'll gain a spare.
Old April 25th, 2019, 06:44 AM
Davis's Avatar
Davis
Davis
94 NAS D90 6.2LS
He did mention he already did that in the OP, btw.
Old April 25th, 2019, 07:48 AM
Chris B
I and others have had plenty of problems with defective coils from Bosch. It's not a brand I favor any more.
Old April 25th, 2019, 07:50 AM
gwmckee
George
1994 NAS D90 #1919
What brand do you recommend? I replaced a new(ish) Lucas coil with the Bosch. Also, the problem manifested when I had the Lucas coil installed. The first thing I did was replace it with the Bosch and continue to have the same issue.
------ Follow up post added April 25th, 2019 08:54 AM ------
I did... no codes.
------ Follow up post added April 25th, 2019 08:55 AM ------
I replaced the distributor about a year ago with one from Power Spark in the UK. I got the one with the amplifier relocation kit on it.
Old April 26th, 2019, 07:34 AM
nyclandrover
Simon
1987 90 TDI Auto
Something else to try. I had a similar fault on a 3.9 RRC, it would cut out after 20-30mins of driving and refuse to start. I found that the coil was generating a spark just fine but when it got to the distributor it would just disappear. Everything was set-up correctly, it was very odd. Eventually I realized that there was a bad ground and the spark was travelling down the rotor arm and grounding through the distributor to the block rather than the the HT leads to the plugs. I put it down to a poor earth between the block and the heads. I added an earth strap from each head (on an exhaust manifold stud) to each suspension turret mounting bolt which fixed the issue. When I inspected the rotor arm body and the distributor shaft closely there was definitely signs of arcing between the 2. Not sure how the plastic rotor arm body did this?? A quick test is to carry a spare rotor arm with you. When you get the vehicle to a failed state (I was normally on the side of the Southern State Parkway!) pop the distributor cap and replace the rotor arm with the spare and it should fire right up, it did in my case. This will keep you going for another 30 mins until the problem occurs again. I think the heat build up in the distributor and build up of carbon from the arcing created a better conductor than the proper route to the plugs/heads, in addition as the engine got hot the resistance between the block and the heads increased. Fitting earth straps bypassed this and fixed my RRC..
Old April 26th, 2019, 08:46 AM
88b9p
Jim
1994 D90 SW
George- Have you checked your voltage coming into the coil when it dies to see if you have 12v coming from the ignition switch to try to isolate if the issue is at the coil/distributor or power supply issue?
Old Today, 09:18 AM
gwmckee
George
1994 NAS D90 #1919
OK Guys... thought I would close the loop on this one. Turns out that after the engine got to operating temperature, the coil pick-up in the distributor would stop sending its signal to the ignition amplifier resulting in no spark from the coil. The way I found it was by measuring the resistance on the pick-up leads when the engine was cool and again after it would warm up and die. When cool, the resistance was 3,300 ohms... within spec. Right after the engine would die, I checked again and the resistance was measuring open circuit. To prove my hypothesis, I swapped in a spare distributor that I had and the truck ran fine for 35 minutes before I shut it off. With the old distributor, it would run for 15 minutes or so and then crap out.
Thanks to everyone who provided input!
Old Today, 02:04 PM
cowboy
Kudos, stud!
Old Today, 02:16 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Congrats on sorting out the issue. Good that you had a spare. There are a few modern and reliable dizzy options out there. Give Mallory a look.
Old Today, 02:28 PM
gwmckee
George
1994 NAS D90 #1919
I've got a little more troubleshooting to do in order to determine where the failure is in that loop. My gut tells me it's in the relocation bit that I got from Powerspark in the UK. Here is a picture of the relocating wire from Powerspark. The frayed end that attaches at the distributor is what concerns me. I had a shop do some work that required pulling the distributor (i know... I know...) and I think they may have stressed the wire getting it out. Figure I'll use a heat gun to warm up the wire and then the pick-up and see which point fails.
I've seen a few threads here that call the Mallory setup into question so I haven't thought about using it. Glad to hear it's been working for you, Russell.
FS: 1994 NAS Defender 90 ST hardtop/softop - AA yellow signalMTB The Flea Market 1 April 14th, 2018 05:23 AM
NAS 90 ST dome light fitting issues KKilo23 Defender Technical Discussions 5 October 3rd, 2013 08:34 PM
Safety Devices 110 Wagon and NAS 90 Wagon cages in stock ECR Vendors 2 March 3rd, 2011 03:22 PM
Seat Box Lid Part Numbers 94 NAS 90 Raleigh D90 Defender Technical Discussions 2 June 19th, 2009 08:57 PM
Tuffy console '97 NAS 90 with Auto ronward Defender Technical Discussions 5 October 7th, 2003 08:39 PM
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
