Spring Shackle bushing: need chassis weight? - Defender Source
Old April 14th, 2019, 09:32 PM
RustCollector
Andy MacInnis
S3 88 '73
Hello, all.
My Series 3 '88 has a new chassis and new spring shackle bushings all around. I have parabolic springs on it, if that matters.
I have heard that before torquing down the shackle bolts, I should add weight to the chassis to compress the springs to about half of their travel. Then the bushings are torqued in the middle of their rotational range.
Anybody done this? Am I buying bags of sand and loading up the bed, or is there a preferred way?
And does the front end matter, or just the rear?
I'm just full of questions today. I'd love some good ole leaf spring wisdom here.
Cheers.
Old April 15th, 2019, 10:17 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
I've tried it that way, and tried it without any load. To be honest I haven't noticed any difference.
Old April 15th, 2019, 10:34 AM
RustCollector
Andy MacInnis
S3 88 '73
OK, so you didn't find a difference either way.
Good to know. Thank you for your reply.
I wonder if it has anything to do with longevity of the bushings.
Curious to see what other opinions are out there.
Old April 15th, 2019, 12:06 PM
The only way to do this correctly is as specified in the factory manual.
Tighten the shackle bolts until they are snug but do not torque them. Same with the nuts on the end of the bolts.
Drive around a little to settle the springs, then do your final torquing. This locks the inner steel sleeve of the bushing to the shackles at the correct position which should be about halfway through its available travel.
By doing it this way, getting the bushing torqued down with the vehicle at resting height, the rubber in the bushing has the ability to absorb the spring movements without stretching too far in one direction and possibly tearing.
FWIW, front shackles should be at about 60 or 75 degrees off the chassis. Rear shackles should be closer to 45.
The methodology of torquing the bushing at its resting position applies for any similar metalastic bushing. On the coil sprung vehicles, if you torque your panhard rod and trailing arm-to-axle bushings while the vehicle is a on a lift and the axles hanging down at full droop, don't expect a ton of life out of the bushings.
Present:
1960 SII 109" Tdi- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca" (lives again)
2008 RRS SC- "The Supersofa" -wallet thinner
Past:
1991 RRC- never got a name- long since recycle
1987 RRC- "Chewy 2" Sold 12/18; now in NJ
Old April 15th, 2019, 12:53 PM
RustCollector
Andy MacInnis
S3 88 '73
Thanks for the wisdom, Skinny Pete.
So, no sand bags. Drive around a bit with the nuts snug, then torque afterwards.
I think I can manage this.
Cheers
110 Chassis weight lrnasd90 Defender Technical Discussions 7 August 15th, 2018 08:01 PM
Weight surprise at scales and spring question KevinNY Defender Technical Discussions 0 March 2nd, 2006 12:34 PM
Why not remove the inner bushing sleeve? ezzzzzzz Defender Technical Discussions 0 June 10th, 2004 07:00 PM
Spring Isolators wicks Defender Technical Discussions 16 January 28th, 2004 02:37 PM
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
