Got half a question answered - Defender Source
Old February 2nd, 2019, 10:41 AM
scrubs
henery
1974
And like the second half :--)
Putting a " Defender" 200tdi into a series,
Was mentioned to cut right chassis motor mount off turn it upside down and resold back on for proper fit,
What motor mounts are needed?
Series Or Defender motor mounts?
Thanks very much
If I was misinformed please speak up
Old February 2nd, 2019, 11:20 AM
giftshopduane
Chris luciano
72 Series 3 88"
You need the LH mount off the motor (Series) cut he RH mount of the chassis, and weld the LH upside down.
I took both LH engine and removed both chassis mounts, moved my 2.5 forward 4-5 inches and welded them to the chassis.
I also am using an LT77 and LT230, I removed the series tc cross member and made my own mounts for the LT230, I can send you the patterns for these if this is what your doing.
This places the shifter in the center of the series tunnel cover, Im running E-fan and will make some custom linkages for the diff lock and hi LO
Hope this helps
Old February 2nd, 2019, 12:14 PM
scrubs
henery
1974
Chris,
Thank you for sharing,
Yes this is exactly what's in progress,
Will PM you for more tips and tricks
Old March 7th, 2019, 06:17 PM
captainz's Avatar
captainz
Jon Stevens
1965 109
I’m looking at doing the same surgery into a 109 pickup. I don’t have an extra 2.25 LH mount just yet. Did you move the mounts forward in order to drop in the motor or to be able to clear the seat box with the trans? I am putting in a 2.5td (I know, I know) mounted to the 2.25 trans in hopes of bolting in a 200tdi later. Will I need to relocate both mounts now or both later when I put in a lt77?
Old March 7th, 2019, 07:18 PM
LRover's Avatar
LRover
J. Michael McCaig
If you are going to use the original 4spd transmission, you only need to alter the right side engine mount because of the timing cover/injection pump. The left side mount works with the 19j. The turbo will interfer with the steering box on lhd trucks.
Old March 9th, 2019, 06:40 AM
captainz's Avatar
captainz
Jon Stevens
1965 109
Thats helpful. I’m planning to install a P38 power steering box as I have LHD. Also-the truck used to be 2.25 petrol—my understanding is I’ll need to at least replace my diffs with a higher ratio to get above 40mph. Where’s the best place for me to find those?
Badger Half Cab w/Free!! half Tonneau mattwhite For Sale - Parts 5 April 5th, 2012 09:14 PM
Any A/C question answered Overlander Defender Technical Discussions 0 May 8th, 2007 10:31 AM
Tough Speaker Question gtg067i Defender Technical Discussions 3 March 4th, 2005 01:04 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 11:30 AM
Main Gearbox Question dbwitt Defender Technical Discussions 3 April 10th, 2004 06:26 PM
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
