Defender Doors on Series IIA Bulkhead - Defender Source
Old July 24th, 2019, 10:29 AM
JasonG
Jason
1964 Series IIA 109
Has anyone mounted defender full doors on a series IIA bulkhead? I have been running into an issue with the door hitting the dash of the bulkhead. Any help would be great! Thanks!
Old July 24th, 2019, 11:23 AM
Scott Preston did that. I seem to recall he cut out the door card to clear the dash. I contemplated using newer doors on my own IIa, and I thought maybe the lift up handle doors would fit better, but never tested that theory. Another thought I had was cutting the end off the dash and moving it in a bit to create the needed clearance.
Present:
1960 SII 109" Tdi- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca" (lives again)
2008 RRS SC- "The Supersofa" -wallet thinner
Past:
1991 RRC- never got a name- long since recycle
1987 RRC- "Chewy 2" Sold 12/18; now in NJ
Old July 24th, 2019, 01:22 PM
JasonG
Jason
1964 Series IIA 109
Thanks! I am looking at the same issue. I do not want to cut door card. I might just make a small modification to the bulkhead to allow the door to clear and seal.
Old July 24th, 2019, 02:59 PM
dporter110
David Porter
1995/D90
Which hinges are you using? The Series III or Defender hinges cause the door to hit the bulkhead. Series IIA hinges should allow the door to go all the way to the fender without hitting.
Old July 25th, 2019, 03:06 PM
JasonG
Jason
1964 Series IIA 109
I am using the defender hinges. It does not seem to make a difference when I use either the series or defender hinges. This inside of the door is hitting the dash of the bulkhead. Might make about 3-4 inch modification to the dash...
Old July 25th, 2019, 03:26 PM
seriessearcher
Sean
1971 Series IIA Dormobile
I would never modify a Series Bulkhead given the scarcity of them. Just me personally. I would modify the door cards first.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
