Bonnet / Hood Stuck on Series II - Defender Source
Old May 10th, 2019, 03:29 PM
DrZ123
Zach
My '59 series II bonnet is stuck
I just got the truck, the first time it was very difficult to open, I had to pry it open while pulling the hood release and it finally popped. Taking off the grill didn't help.
Now, trying for the second time, I can't get it to open. I tried prying while pulling the latch and it won't budge.
Any advice?
Old May 10th, 2019, 04:35 PM
1974 Series III "Heavy"Lightweight
WD40 is your best fiend....
Old May 10th, 2019, 06:50 PM
DrZ123
Zach
I don't event know where I would WD40!
Old May 10th, 2019, 07:36 PM
Chris B
72 + D1 drivetrain =?
Spray the Bonnet catch and Latch in the center of the hood. Its probably gunked up/rusty from lack of use. Once free of gunk. Don't be afraid to use plenty of Penetrating spray to get it loose then again once the bonnet unlocks. Make sure the cable gets lubed to. D
Now once that is done and you close the bonnet again, open it up in a few days and repeat the generous lubrication routine.
Old May 10th, 2019, 07:41 PM
DrZ123
Zach
Ok will try. No cable on it as it's a series. Just the latch as far as I can tell...
Old May 11th, 2019, 06:04 AM
DrZ123
Zach
I emptied a whole damned bottle of WD on there and no budge!
Old May 11th, 2019, 07:31 AM
Contractor's Avatar
Contractor
Will
1969 IIA
If you look at the latch mechanism through the grill, the catch/hook on the right side of it is what operates the locking mechanism. Take a flat screwdriver and stick it in there and pry it over toward the right side. Pull up on the hood at the same time.
Old May 11th, 2019, 07:36 AM
DrZ123
Zach
I'll try more with a screwdriver. The latch pull releases that lever however I'll try to pull at it even more.
There is another latch on the left side but I don't think it's meant to be released.
Contractor's Avatar
Contractor
Will
1969 IIA
See how it’s slotted?
Picture is probably sideways, but Like this:
Old May 11th, 2019, 08:26 AM
Chris B
Leverage/prying, hood probably moves up and down a fraction. The pry bar/screwdriver will help it a little.
And go down the parts store get more PB Blaster etc. Letting this stuff soak in over night is always helpful. At worst, a little heat will have to join in the fun.
Old May 11th, 2019, 09:36 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
More likely the latch unit is out of adjustment/worn out. Loosen every bolt and wiggle it open. Check the bonnet is centered in the hinges.
I voted to leave the EU, not a deal.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 2hundie 5 speed (for sale)
05 D3 HSE
97 XK8 BRG FHC SOLD
94 RRC County swb
Old May 12th, 2019, 08:26 AM
DrZ123
Zach
Had to unbolt the entire latch mechanism from underneath and finally it opened.
It appears the pin the sticks off the hood was bent, and getting jammed into the latch mechanism!
Luckily RN had a NOS pun for $25. Hopefully that puts an end to this!
Old May 20th, 2019, 10:11 AM
DrZ123
Zach
So I got the NOS pin, and of course, nothing is easy in life. The bonnet striker bracket plate (original part 330548), holds the pin onto the bonnet. The plate has a nut welded to it, and the pin screws in through that nut.
Well, because the original pin was bent, I can't get it unscrewed from the plate. Have tried WD40 and alot of force, won't come loose.
I contact ZG at RN and they don't have a replacement plate, and I can't seem to find one anywhere.
Any suggestions would be appreciated!!
Old May 20th, 2019, 10:30 AM
Parrie's Avatar
Parrie
Parrie Willette
1989 D90 P/U
Have you tried posting on the guns & rovers forum? Lots of series folks on there. Also try Ike at Pangolin 4x4. GL
Old May 20th, 2019, 11:55 AM
It has to be straight enough to unscrew from the bonnet frame. That's a pretty fat thing to be so bent that the threads are jammed.There should be a locking nut. That's probably what's holding you up. Did you get the striker plate thing off? I assume yes. Get the locknut loose and it should unscrew from the bonnet.
1965 2A 88
1971 RRC
1989 RRC
Old May 20th, 2019, 11:58 AM
DrZ123
Zach
I unscrewed the striker plate from the bonnet, with the pin attached.
I took off the locking nut from the pin, which came off no problem.
It is the put itself I can't get out of the plate because it's bent.
Old May 20th, 2019, 12:20 PM
Oh well if I'm understanding this right you just have to bend the plate back straight then, that's all.
Usually what happens is someone takes the bonnet off and sets it upright on end. A gust of breeze comes along and pushes bonnet over and it almost every time lands on the pin, bending the mounting structure.
1965 2A 88
1971 RRC
1989 RRC
Old May 20th, 2019, 12:40 PM
DrZ123
Zach
It's the pin itself (which is basically a big bolt) that is bent, not the plate. Hence why it wont unscrew unfortunately.
Old May 20th, 2019, 12:50 PM
Again, it probably took a hit from falling. Whichever way it's bent, hammer it the opposite way and see if that won't let you at least get it to turn.
1965 2A 88
1971 RRC
1989 RRC
Defender Bulkhead, Seatbox, Bonnet and some Series IIA body parts abraded For Sale - Parts 2 December 22nd, 2017 09:02 PM
Want Series Razor bonnet Himalaya Wanted 4 May 8th, 2017 08:46 AM
Series I II IIa III Heystee disc brake conversion kit kullberg Series Technical Discussions 8 June 14th, 2012 02:42 PM
Series Scissor Hood Prop Bottom Mount Thingy Wolf Fabrication Wanted 1 August 17th, 2011 05:24 PM
Rare NOS Series II and III Parts on the way SafariHP Vendors 0 January 18th, 2011 06:22 PM
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
