Alpine Glass Install? - Defender Source
Old October 14th, 2018, 08:03 PM
Dartmouthbrian
1973 Series III 88
If I were to replace the window seal for the Alpine Glass on a Series 2a 109, does anyone have any good pictures or reference for how to do that?
I did a search and didn't find anything here, found an 8 yr old post on Rovers North, but the pictures are gone of course.
Any help would be appreciated!
Old October 14th, 2018, 09:10 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
Pretty straightforward. All you need to do is get the tool to install the locking bead. It's about $15. on Ebay. Email me tomorrow [email protected] and I will dig mine out and take a picture. I'm pretty sure it also has the part number on it to order. You can do it without the tool but it's a real PITA! Tool makes it slick as snot.
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
2003 Mini Cooper S (The gocart)
1995 Range Rover Classic 300 Tdi 5 speed SoftDash (My Son's)
"Be the person your dog thinks you are"
take it to a glass shop if you have never done it.
1965 2A 88
1971 RRC
1989 RRC
Old October 14th, 2018, 09:18 PM
Dartmouthbrian
1973 Series III 88
Thank you both!
Old October 14th, 2018, 09:20 PM
scooter's Avatar
scooter
scott
1986 110 Country
I have both to re-install on my truck. rooted all the way thru. if you find the tool on E-bay can you post a link? Thanks.
Old October 14th, 2018, 09:22 PM
Dartmouthbrian
1973 Series III 88
Will do!
Old October 14th, 2018, 09:27 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
It’s not difficult. Use plenty of spray lubricant to help things along. Don’t see the point in taking it to a glass shop just because you’ve never done it before. You can easily learn. This is the tool I bought. Seemed to work fine.
https://www.amazon.com/Lisle-47000-W...pop_d_pd_title
Old October 14th, 2018, 10:38 PM
There's a high learning curve and the chances of dropping the glass is very likely. It's far easier to do this with the roof upside down on sawhorse and on grass so if you drop it it won't break.
If you decide to do it yourself, buy plenty of gasket and lock strip. You want to overstuff the gasket. Like dry fit without the glass and cut it 1/2 inch too long. It will shrink quite a bit over the first year.
It helps to have someone holding the glass while you do the lock strip.
1965 2A 88
1971 RRC
1989 RRC
Old October 15th, 2018, 09:18 AM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
94ST #646 & 91 Camel Trophy 110
Do glass shops or the factory use any kind of silicone sealant or something else when installing/reinstalling this type of window? I just took 2 windows out of my NAS fiberglass hardtop and reinstalled them...now they leak badly. There was a boogery substance in the gasket when I removed the windows. I wire brushed it out.
Old October 15th, 2018, 09:42 AM
roverx's Avatar
roverx
Scott Preston
If done correctly it should not need sealant. That stuff in the channel is to make it slide into place during install. I prefer to use foamy glass cleaner.
Scott Preston
Old October 15th, 2018, 09:59 AM
roverx's Avatar
roverx
Scott Preston
Here is a picture of the locking strip tool. CR Lawrence will not sell to you unless you have a business license. The tool is $3. You can get them on ebay for $10 - $15
https://www.ebay.com/itm/General-Pur...8uqS:rk:1:pf:0
Rovers North sells the new gasket and locking strip by the foot. Well worth installing new if you redo the windows. I'm in the process of installing alpines into my military hardtop. I will try and post a short video when I install the glass. Here are a few of the cutting process.
Name:	Rover glass tool.jpg
ID:	402250   Click image for larger version
Name:	Alpine install layout.jpg
Name:	Alpine install  hole 2.jpg
ID:	402254   Click image for larger version
Name:	Alpine install  cut 1.jpg
Name:	Alpine install  complete other side.jpg
ID:	402258   Click image for larger version
Name:	Alpine install  inside both.jpg
Scott Preston
Old October 15th, 2018, 10:32 AM
rovertrader's Avatar
rovertrader
Dale
Tithonus 110, D-90, 110 S/T 5-door
make sure you are using the correct glass/seal combo as Series glass is thicker...
Old October 15th, 2018, 03:36 PM
Dartmouthbrian
1973 Series III 88
Thanks everyone. Much appreciated!
Old October 24th, 2018, 11:32 AM
DonQuixote's Avatar
DonQuixote
Mike Shaw
Red 1970 Series IIA 88
Brian-
There is some good (but scant) info on Pangolin's site, as well as the installing tool and the the rubber gasket (by the foot). Someone there may be able to guide you as well.
https://pangolin4x4.com/item/359
I just bought 1 foot of the gasket from Pangolin to patch the half-inch gaps in my Alpine window seals. I guess the seal contracts over time, and you get a little gap to patch.
Good luck with the project.
Living it...
Old October 24th, 2018, 11:54 AM
DonQuixote's Avatar
DonQuixote
Mike Shaw
Yes, exactly, regarding the shrinkage. I just made little 1/2 plugs out of the stripping. I have enough problems with leaking water, and that was a super easy fix. I think it is a good idea to install with the weather stripping cut on the bottom part of the window, not the top. So when the weather stripping does shrink, the gap will let in less direct rainfall.
Here's a picture of the gap.
Living it...
Old October 24th, 2018, 12:50 PM
roverx's Avatar
roverx
Scott Preston
Here are a few pictures. I will do a video and post when I finish painting the roof and re-install the alpines. If you want to call 615 681 8441 I can give you a quick 10 min walk through. As mentioned always cut the gasket long and squish into place. It will shrink over time. Once you get the gasket tool and a basic set of plastic tools from Harbor Freight it's pretty easy.
Name:	alpine gasket 1.jpg
ID:	403062   Click image for larger version
Name:	Alpine gasket 2.jpg
Name:	Alpine gasket 3.jpg
ID:	403066   Click image for larger version
Name:	Alpine gasket & tool closeup.jpg
Scott Preston
Old April 2nd, 2019, 07:14 PM
bamanuke's Avatar
bamanuke
mike hall
'97 alpine white sw # 0127
thanks!
got mine done yesterday. fab'd up a strip tool from a harbor freight router wrench. used silicone spray lube. also warmed the gaskets/strips in heated water. first one was a pain, second went much quicker.
Name:	alpine window tool.jpg
Old April 3rd, 2019, 08:57 AM
FLY CUBS
Tim
1989 Land Rover 90
You can also use this tool: https://www.amazon.com/Lisle-47000-W.../dp/B000COA1CQ
I've done two sets of Windows on a Series. Rovers North has the best seals, sold by the foot.
In lieu of using silicone, I just use SprayWay aerosol glass cleaner, and lots of it. Lubricates nicely for the install without making future paint jobs a possible nightmare due to contamination.
The key is to do the bigger seal first, then once the glass is all set, do the locking strip. Put the ends of the main seal on the bottom and and locking strip on the top- won't leak assuming you didn't go way short on the ends.
1989 Land Rover 90 LHD
1976 Series III - SOLD
1940 Piper J3F-50
Alpine and Sliding Glass Window Removal mgrgpg Defender Technical Discussions 11 April 5th, 2018 01:49 PM
Alpine Stereo Install w/ Head Unit Amp jruti Smaller Projects 0 July 10th, 2013 11:38 PM
Alpine Window install (locking strip gaskets) o2batsea Defender Technical Discussions 0 February 20th, 2013 08:15 AM
Defender glass choices-lessons learned Overlander Defender Technical Discussions 1 May 14th, 2010 09:51 PM
Looking for Alpine roof glass windows Brim Wanted 0 October 15th, 2007 06:36 PM
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
