Ostrich Wing Awning - Page 2 - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old March 26th, 2019, 10:18 PM
77SouthAfrica's Avatar
77SouthAfrica
Theo Ferreira
1991 110 V8
Originally Posted by Fred Lobster View Post
Will you be coming up for SCARR?
I wish I could, I will be at Overland Expo East in the Fall though. Headed to Flagstaff for Expo West in May and can’t commit to that and SCARR. I think Robert might be there though and he has some awning swag to show off 🙂
Old April 9th, 2019, 07:54 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Do you have any that would fit a 90?
Old April 9th, 2019, 09:22 PM
77SouthAfrica
Theo Ferreira
1991 110 V8
Thanks for the question. It only comes in the one size and it can be fitted to a 90, but it will extend about 27” from the front of the roof rack. It can handle a 39” cantilever mount from the front most mount point so that is well within spec.
The question is are you ok with the extension slightly coming into your top left or top right line of sight.
Old April 10th, 2019, 09:02 AM
80sailor
Tripp
1979 Series III 88 (ex-MOD)
This looks great.
What sort of mounting hardware comes with it?
1979 Series III 88
2017 Discovery V
1973 Series III 88 (sold)
2000 Discovery II (sold)
Old April 10th, 2019, 10:40 AM
77SouthAfrica
Theo Ferreira
1991 110 V8
Originally Posted by 80sailor View Post
This looks great.
Thanks this is a great piece of kit. The hardware kit supplied with it consists of
1. 2 x T-brackets which are vertically mounted on a M8 channel found on the long edge of most roof racks.
2. Z-bracket to brace to the perpendicular edge of the roof rack at the rear mount point.
3. Leading arm support bracket (to mount on the opposite rear corner to support the leading arm when deployed
note: If mounting on a Front Runner rack or other bolted-style rack we strongly suggest purchasing a second bracing Z-bracket to mount at the front mount also to protect the rack
If using load bars with center bolt channels:
Heavy duty L-brackets are available at a nominal charge. In this case no bracing Z-brackets are needed.
If using a tubular rack/roll cage to mount there are a number of tubular clamp fabricators I can suggest.
Old April 11th, 2019, 07:56 AM
Fred Lobster's Avatar
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
PM sent.
Old Today, 01:29 AM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
what's the dimension when it's packed?
Also, any idea/suggestion how something like this could be mounted to a NAS SD basket? Thanks!
Old Today, 02:01 AM
77SouthAfrica
Theo Ferreira
1991 110 V8
It is about 106” long and 7” tall packed.
Depending on the basket design (I have seen a few varieties of SD basket, not sure which you have) you can source a round bar clamp from Fourtreks.com, they carry a various diameter clamps for many tubing sizes and cater for most awnings and tents mounted to round bars. I will work with their owner to configure a specific one for the bolt holes configuration needed for this awning, if none of their stocked versions work.
If you can PM me some photos and dimensional measurements of your basket I can give you a more precise answer. In short, it should not be a problem, but let’s look at some specific details of your rack.
Thanks for the interest!
Theo
right hand side outer wing skin eric_besore Wanted 1 August 22nd, 2005 01:24 PM
Wing Vents mlw911 Defender Technical Discussions 17 June 28th, 2004 10:26 AM
Need Left Wing outer shell vnrover Wanted 8 April 8th, 2004 11:56 AM
wing protectors Campbell Wanted 7 March 25th, 2004 04:21 PM
For sale: Daimond Plate Half Wing Protectors Burke For Sale - Parts 0 January 25th, 2004 10:20 AM
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
