Secret hand shack - Defender Source
Old November 3rd, 2019, 03:06 PM
nealcain's Avatar
nealcain
Neal Cain
1988 D110
Secret hand shack
Ok what is the secret to installing the window crank channels on the lower door glass.=)
I busted up the old channels and chipped up the glass trying different ways and now have new one and do not want to bust these ones up.
Thanks a bunch
Old November 3rd, 2019, 06:43 PM
Tbaumer's Avatar
Tbaumer
Ted Baumer
1986 LHD 110
Might not be recommended, but after many attempts using Windex glass cleaner & even dish soap, I wound up turning a flat screw driver to open the channels just a little bit - still a very tight fit, but at least possible & the rubber grabs well. Haven't had a problem with them.
Old November 4th, 2019, 10:30 PM
nealcain's Avatar
nealcain
Neal Cain
1988 D110
Hesitant to try the screwdriver technique but will give it a try this week end and report back.
Old November 13th, 2019, 01:26 AM
nealcain's Avatar
nealcain
Neal Cain
1988 D110
I cut a channel in a piece of wood and slid it on the glass, put 2 clamps on put some pressure on it then smacked it with a hammer. This technique put a bend in the channel but its on.
Old November 13th, 2019, 08:45 AM
Ibrouting's Avatar
Ibrouting
At that point I would turn it into a ST....
'94 D90 300TDI "B.A."
Old November 13th, 2019, 10:34 AM
Vedrover
Alex
1988 Land Rover 110
Did it on all 4 windows. Then had to redo 2 front ones because I put them on backwards (I know, they are technically the same, but but my inner OCD'ed alter ego wanted the glass labels matching).
KY Jelly and gentle mallet tapping. Worked like a damn and then washes off with water.
From another forum on "what killed the British auto industry":
- "I'm pretty sure it was Joseph Lucas."
- "Ah, The Prince of Darkness with his three position switch: "off, flicker and dim"."
Old Today, 01:51 AM
nealcain's Avatar
nealcain
Neal Cain
1988 D110
Hahaha!!! Vedrover I did not see that coming.lol
Being able to wash away the lube makes this a great idea.
Old Today, 02:01 AM
sgo70's Avatar
sgo70
Sean
2001 110
Can you use that for anything else???
Sean
2001 110 300tdi
Old Today, 08:58 AM
Vedrover
Alex
1988 Land Rover 110
Sean
Yes, for easier pulling of the wiring harness through the frame 🙂
You actually can and I actually did.
After all, that’s what the product has been designed for: easier sliding of large items through tight spaces 🙂
Old Today, 09:06 AM
modernbeat's Avatar
modernbeat
Jason McDaniel
2-Door Diesel RRC
If your modesty doesn't let you buy KY, then just buy glycerine. I've used it for window rubber installation for ages.
I used to use dishwashing soap, but found that it would stick around after the install and would start corrosion trapped under the rubber.
Jason McDaniel
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
