ministry of defender AC units? - Page 2 - Defender Source
Old September 19th, 2019, 11:26 AM
headdamage's Avatar
headdamage
Andrew
Exmil 90 & 110, RRC 200tdi
That is a very attractive kit, the concept of adding AC to my old exmil 90 is mind blowing.
Old September 19th, 2019, 01:00 PM
stancey's Avatar
stancey
steven stancey
1988 Defender 110 LS, 1993 130 tdi
Curious how well this does when you aren't adding the puma dashboard. That would just leave demister and leg vents, nothing that you can point at your body at least my webasto unit can point the vents into my general area. I emailed them some questions about if the air intake on top of the wing is being removed and venting if you don't plan on upgrading to the puma dash.
Sent from my Pixel 2 XL using Tapatalk
Old September 19th, 2019, 01:05 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Part of the reason I invested in a lower dash bit was for the vents and additional fan, this looks interesting for sure! There do seem to be an abundance of kits for defenders and AC right now. My only concern at the moment is leg room with the underdash setup, anyone offer any insight on if its dramatic?
Old September 19th, 2019, 02:39 PM
MW469's Avatar
MW469
Marcus Whitaker
1990 defender 110
I met Johnathan in June when I was back. He's a good guy and has put a lot of effort into the design. We plan to start installing in all our trucks. His operation is in Lincoln where the Cool Air Logan place is. The box does sit in a pretty hostile environment especially on a 200tdi with a bigger turbo. Some sort of extra heat shield is probably in order when installing.
Old September 19th, 2019, 03:24 PM
stancey's Avatar
stancey
steven stancey
I'm wondering if you can keep the lower unit and just plumb in the other unit. Dual / single zone ac. I'm pretty sure my ls would be under 10mpg with that upgrade...
Old September 21st, 2019, 04:39 PM
bish1865
Bruce Bishop
1985 Defender 110
Put that kit on a military 110. I was very impressed with it. We just vented one through the mud console with rotating vents tied into the lower dash. Should work great.
Old October 4th, 2019, 11:08 PM
BXL'D
Dane
1992 110 200TDi
Interested to see how this pans out for others. Looks like an intriguing design!
Old October 4th, 2019, 11:45 PM
FRM's Avatar
FRM
ROGERS MASSON
62 Series iia 109 w/200tdi
Hello everyone, I purchased their ac/heat unit a few months back and will be installing fairly soon. I'll be dropping it in to my 62 Series iia 109, so the dash/etc. will be funky, but I like a challenge. Will be sure to post pictures along the way. Also, for the record, had great interactions with the owner and staff. Very helpful, responsive, and are doing a lot of cool work.
Old October 5th, 2019, 08:13 AM
scrubs
henery
1974
FRM,
PM sent
Old October 5th, 2019, 04:08 PM
I looked at this for a while .... basically it doesnt appear to pull in external air but recirculates air from the cabin via a hole cut in the top of the footwell.
Old October 5th, 2019, 04:55 PM
One Ten's Avatar
One Ten
Sam
1997 NAS BR110
You are correct
Old October 5th, 2019, 07:55 PM
LiquidMoose's Avatar
LiquidMoose
I noticed this as well, but don't understand the ramifications, is using recirculated air not a good thing to do?
Old October 17th, 2019, 08:59 PM
Uk4x4fan
Tom Bache
1990 90 SW
As a followup to a previous comment, why does the lower dash in the Defender (LHD) get so hot? Thought it was just mine. Thought maybe the lower dash is toast inside. Heater valve closed manually, fan is off and still get quite a draft of warm air. Only when moving...
Tom
Old October 17th, 2019, 09:08 PM
stancey's Avatar
stancey
steven stancey
I have been chasing that for months. I'm actually going to buy an evap smoke machine bc it's really pissing me off. I can tape off the wing vent and still get warm air blowing in through the vents when truck moving. It's either the seal between heater box / bulkhead or a Venturi effect when going at speed and air leaking out somewhere else, then getting sucked in somewhere around the heater???
Old October 17th, 2019, 10:36 PM
Naplm00
M
Plenum door is supposed to be covered in closed cell foam and this foam also acts as a seal when the door is shut. Yours has probably turned into dust
Originally Posted by Rover4x4
I've been rear ended by an fj40 running 50+ as a passenger in a Cherokee, the tool box was in front of the truck. I've been there bruh. Yeah.
Old October 17th, 2019, 10:49 PM
stancey's Avatar
stancey
steven stancey
My box is essentially new. Pulled it apart, painted it, new foam inside, sealed, etc... With the intake taped off, I'm still pulling warm air through vents at speed. My guess is bulkhead heater seal has small gap, which is sucking in hot engine air when moving. I believe this is called the Venturi effect. It must be all the million little air gaps I have throughout the body, causing this.
Old October 18th, 2019, 12:18 AM
Naplm00
M
Yep probably the 9 million other tiny holes then
Old October 29th, 2019, 07:46 AM
Chris B
72 + D1 drivetrain =?
Let's see pictures of these installations!
Old October 29th, 2019, 11:20 AM
bnoonan
Brice
1988 RHD 90
Overland Autoworks in North Little Rock, AR has installed one in that black 110 you can see on their Facebook page. I've been by the shop and talked to them about it quite a bit. I'll be having them install mine in the next month or two. Call Ben and he can give you the skinny.
Old October 29th, 2019, 11:21 AM
haru182
Chase
89 SA 110 R2.8 / 94 AA NAS 90
Pretty sure thats the vote of confidence everyone is looking for.
I'm still waiting on mine to be installed.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
