Door Top Mounting Stud Rusted/Snapped - Defender Source
Old October 24th, 2019, 07:31 PM
WildBoar's Avatar
WildBoar
Derek Borror
1984 110
Going to dig in to this project now. Getting cold....need some door tops.
How do get this apart to a point where I can drill out the broken stud and likely the studs that will broken? If I remove these two outer rivets will that whole panel come off and allow me to remove the glass channel and then remove the small screws to pull the window frame tray out?
ID:	432030   Click image for larger version
Two is one and one is none!
Old October 24th, 2019, 07:37 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Garrison Outfitters has a video that shows how to disassemble them. Think about installing their kit while you have them apart.
Angus
Old October 24th, 2019, 08:07 PM
WildBoar's Avatar
WildBoar
Derek Borror
1984 110
Thanks Mike!
Old October 24th, 2019, 08:37 PM
Naplm00
M
I just drilled from the bottom up then helicoiled the window frame. I now use ss studs with antiseize on them.
Edit: didn't bother with disassembly
Originally Posted by Rover4x4
I've been rear ended by an fj40 running 50+ as a passenger in a Cherokee, the tool box was in front of the truck. I've been there bruh. Yeah.
Old October 24th, 2019, 09:06 PM
WildBoar's Avatar
WildBoar
Derek Borror
1984 110
That may be a good option as well. Will see how bad the felt is....might do the whole kit.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
