95 LWB in a defender shop... Full Build - Defender Source
Old March 27th, 2019, 04:27 PM
Shagey71's Avatar
Shagey71
Sam Hagey
1995 RRC LWB - Alpine White
Well, the old ‘95 that a lot of you know from me dragging it around the country is getting the “Royal Treatment” as we call it here (Royal Overland Company)
What’s the scope of the build?
INTERIOR
-Removed all seats, carpet, matting, dash, headliner, all speakers and wiring, sub box, tire carrier, etc.
-Laid down 2 “mega kits” from SoundSkins on the floor boards, and on the inside of each door skin.
-wrapped butyl and foil deadener on each wheel well, on the roof and sunroof enclosure, and on each door bar.
-laid heat barrier on the roof panel, and the interior firewall.
-100% oxygen free copper speaker wire and power wire ran through the truck to the rear cargo area and to each speaker location.
-stock radio integrated into an Audison bit 1 DSP with Bluetooth for SQ level audio. Door components are MMats German line 3-way and the truck runs a single 8” MMats P2 woofer
-Phillip Sell built rear storage/gun box/pull out bar/woofer box of burned Walnut for cargo area (photos coming)
-snomaster low profile 12v DC fridge
-snomaster 12v icemaker
DRIVETRAIN
-GM Gen III 6.0L v8
•Texas Speed and performance provided: 220r cam, ls7 lifters, chromoly custom pushrods, valve springs, all bearings and gaskets
•new flat top pistons, coated
•862 head swap (higher comp)
•LS2 Intake swap
•hooker cast headers
-Aeromotive stealth fuel pump, and pressure regulator
-holley throttle body and fuel rails
-65lb injectors
-Gearstar Stage 3 4L80e trans with 2500 stall
-Marks lt230 adapter
-built 1:1 Lt230 w/ part time kit
-GoatBuilt accessory brackets for truck spacing
OTHER
-Radflo Shocks
-Rovertyme 3” springs
-patriot Tires
-rovetorre hidden winch tray for stock bumper
'95 RRC CountyLWB - Swapped to a 4.6L, and now working on a 6.0L
'91 LS Swapped SWB RRC
'90 RRC Truggy - loud and proud, but mostly ugly
'95 RRC CountyLWB Beluga Black - Waiting to be great again
Old March 27th, 2019, 07:37 PM
El Matador
Jesus
'91 110 Ex-Mod
Where’s that popcorn emoji?
Suscribed
Old March 28th, 2019, 08:06 AM
Shagey71's Avatar
Shagey71
Sam Hagey
Jesus? Is that you?
Old March 28th, 2019, 08:12 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Nice Sam!
Since you do not need the 4.6 I will send you my address so it's not cluttering up your shop.
Old March 28th, 2019, 08:14 AM
Shagey71's Avatar
Shagey71
Sam Hagey
Originally Posted by Kevin88RRC View Post
Nice Sam!
Ha! It’s at my machinist right now getting darton top hats for a customer’s 95. (Canadian Rangie, actually)
Old March 28th, 2019, 10:24 AM
El Matador
Jesus
'91 110 Ex-Mod
Originally Posted by Shagey71 View Post
Jesus? Is that you?
You can now unequivocally and affirmatively answer the question: “Have you found Jesus?”
Old March 29th, 2019, 12:29 PM
That should fix the lower water hose issue nicely
95' D90
92’ D110 - ZA
defender 110 200tdi to L98 v8 build australia. djm Truck Build-up's & Restores 5 May 16th, 2018 07:21 AM
Defender 110 full set of seats Cliffman Wanted 0 January 5th, 2018 04:14 PM
Defender G4 Full Brush Guard D90Overkill Wanted 4 July 17th, 2017 05:11 AM
Who wants to build me my Defender 110? sigar Truck Build-up's & Restores 27 April 27th, 2017 07:22 AM
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
