1992 ZA 110 projects - Page 7 - Defender Source
Old June 25th, 2019, 03:10 PM
Mall Ninja
Thank you, that is very helpful info! I'll look into those options.
Old June 25th, 2019, 06:15 PM
Grover's Avatar
Grover
Originally Posted by rlynch356 View Post
Spring pin fragments recovered... now to reassemble and drive it
The pin securing the female drive key to the helical gear should be a solid case hardened/ground pin, what I see in this pic appears to be a roll pin. Roll pins are not designed to withstand high torque loads, thus the reason for the case hardened pin.
I would replace with the proper pin.
Glad to know your engine was not damaged...your lucky...
Cheers...
Old June 25th, 2019, 09:07 PM
Grover's Avatar
Grover
The case hardened ground pin (on the left) is .1984 in diameter.
Old June 25th, 2019, 10:12 PM
Grover, i replaced it with a case harder pin (actually used the lower drive gear from another oem distributor)
More updates
Installed an external fuel pump (walbro in-line 255lph) and associates new filters to fix the drop in fuel pressure at 1/2 throttle. Also upgrade the fuel lines to 3/8 on the input side. Total pain in the ass project since both tanks had to be dropped new wiring run, etc.
installed the fuel tank skid and got it all plumbed back up and running. Will test tomorrow on the highway. (Also wanted more fuel at WOT)
Hopefully my batteries will in in tomorrow (dual odyssey 34-1500s) so I can finish the solar hook up and then change the alt out.
And finish the stereo dash console install (1/2 way wires for the speakers)
Gotta love working on a truck where ever original fastener comes off and most can be just cleaned up and reused.
No gunk in the fuel tanks either, same as the oil sump, when I got the pin out.
95' D90
92 D110 - ZA
Old July 1st, 2019, 09:21 PM
Uh oh... time for a new clutch and slave cylinder...
I think everything that can fail has on my watch... so hopefully Im good. Time will tell.
Roverlife at its finest...
95' D90
92 D110 - ZA
Old July 1st, 2019, 09:40 PM
Davis's Avatar
Davis
Davis
94 NAS D90 6.2LS, '91 110 200 TDI
Sorry to see that, but even on a flat bed, that is one great looking truck. not a big fan of matching alloys, but on yours it looks FANTASTIC.
"buy once cry once" comes to mind ;)
Old July 1st, 2019, 09:51 PM
Thank you, the plan is to change them to wolfs at some point.. prob after a year of ownership and I get everything sorted
95' D90
92 D110 - ZA
Old July 1st, 2019, 10:31 PM
Davis's Avatar
Davis
Davis
Well...if you do black wolfs, I’ll like it more... that’d be sweet.
Best way across the US Mike Hippert Defender Technical Discussions 173 April 29th, 2010 03:56 PM
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 03:54 PM
1986 Land Rover 110 Soft-Top Tdi Lurker For Sale - Vehicles 3 June 7th, 2006 10:03 AM
1993 Defender 110 mpodgorski For Sale - Vehicles 11 April 4th, 2006 06:07 PM
Importing a 110 to the States mfreeman17 Misc. Chit-Chat 18 April 14th, 2005 01:02 PM
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
