Brake Servo/Booster and Master Cylinder - Defender Source
Old April 24th, 2019, 02:05 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Looking for the Disco 1 Brake Servo/Booster and Master Cylinder to upgrade my ROW 110 setup.
Kent
1985 Land Rover 110 3-door ST
Old April 24th, 2019, 03:56 PM
Vedrover
Alex
1988 Land Rover 110
Genuine curiosity here: why would a Gen 1 Disco brake servo/MC be an upgrade to an original config?
I just had my MC crap out on me and thought I'd go with a TuffStuff MC/Servo, but ended up ordering a TRW replacement instead (TuffStuff is too expensive in Canada). I figured, original one served well since 1993, hopefully I'll get the same mileage out of this one too.
My thread on the MC/Servo subject here:
https://www.defendersource.com/forum...ferrerid=15874
From another forum on "what killed the British auto industry":
- "I'm pretty sure it was Joseph Lucas."
- "Ah, The Prince of Darkness with his three position switch: "off, flicker and dim"."
Old April 24th, 2019, 04:29 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Not sure of the specifics. Maybe someone can chime in.
All I know is that I have heard on multiple occasions that the D1 servo is a pretty easy upgrade.
Old April 25th, 2019, 06:17 AM
Kent, are you finding the brakes inadequate? Guessing your rig is still drum in the back? I wouldn't think that your truck is any heavier than a stock 109.
Present:
1960 SII 109" Tdi- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca" (lives again)
2008 RRS SC- "The Supersofa" -wallet thinner
Past:
1991 RRC- never got a name- long since recycle
1987 RRC- "Chewy 2" Sold 12/18; now in NJ
Old April 25th, 2019, 06:46 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Yes, drums in the rear. It's like the truck has no power brakes right now, which I assume is due to the vacuum leak. If the repair is required anyways, I figured I would put the bigger booster in, as long as it was a direct swap (like I've heard), and wasnt too expensive or difficult to do. Unless what I have heard elsewhere in this forum is wrong, and the D1 servo will make no difference.
Sent from my SM-G930V using Tapatalk
Old April 25th, 2019, 07:10 AM
They are a double diaphragm 8" servo. The Defender uses a single diaphragm 10". This means the Disco is around 30% larger.
They are not a direct bolt on as I understand it. The bolt pattern is different and the fork connection to the pedal is different. I have not looked at it myself, but that is what I've read.
If you have an original servo from 1985, the later ones (1991+) are quite a bit larger. I've not sure if they work with the older masters.
Condensation leads to rust, Rust leads to anger, Anger leads to hate, Hate leads to suffering.
Old April 25th, 2019, 02:05 PM
RamblerRob
Rob Apps
1967 series 2a 109 NADA
I put one into my frankenrover 2a. Bolt pattern is different but it's ok because you need to space it out a bit from the pedal box anyway so you can make an adapter plate to space it and adapt the bolt pattern. I just pinched the forks to fit them.
Old April 29th, 2019, 09:37 AM
rangielandy
Paul Daniels
1995 rrc
Pic of the one I have, it's in a 1997 disco
2-port to 3-port brake master cylinder Miller Defender Technical Discussions 2 April 30th, 2013 03:10 PM
Brake Servo and Master Cylinder Miller Wanted 3 April 6th, 2013 08:51 AM
Brake Master Cylinder Leak chris snell Defender Technical Discussions 12 September 28th, 2011 08:50 AM
Master Brake Cylinder Replacement: Questions! NC Rover Defender Technical Discussions 2 April 7th, 2011 11:20 AM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 09:10 PM
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Search Engine Friendly URLs by vBSEO 3.6.1
