-   -   Oil Pressure sensor 2.5TD to 200tdi Conversion (http://www.defendersource.com/forum/f6/oil-pressure-sensor-2-5td-to-200tdi-conversion-73879.html)
richord October 16th, 2016 04:58 PM
I replaced my 2.5TD with a Discovery 200Tdi.
The 2.5TD had two sensors on the oil filter assembly but the Discovery 200Tdi only has one.
Is the sensor on the Discovery 200Tdi the oil temperature sensor or the pressure sensor?
Which wire should be connected the this sensor? I have one wire that is White with a Brown tracer and the other one is Red.
Is there no oil pressure sensor on the Discovery 200Tdi?
Ignotus October 16th, 2016 05:34 PM
The oil pressure switch should be on the oil filter housing and it will have a white/brown wire from it to the gauge.
Retroanaconda.com for parts info
Solid red wires are used in the lighting circuits.
