-   -   2.5NA Wiring - Help Needed (http://www.defendersource.com/forum/f6/2-5na-wiring-help-needed-70411.html)
ben little May 4th, 2016 04:52 PM
Nearing the end of my 110 restoration and I cannot seem to figure something out.
There is a single 'green' wire coming off the inside of the injector pump - Where does this connect to?
Can someone possibly post a pic of the loom that it plugs into?
Thanks in advance.
Red90 May 4th, 2016 04:59 PM
The only connection to the injection pump should be for the fuel solenoid and it should be white with black stripe which is direct from the ignition switch. Green is switched and fused power.
You can download the factory manual here: pdf Land Rover Manuals | Landroverweb.com Wiring schematics are in there.
ben little May 4th, 2016 06:11 PM
Thanks... Yea I've looked through the manuals and my truck seems to have different colors than what the manual suggests. Could be the ex-MOD... Not sure.
The wire is definitely green (solid green IIRC).
Ash May 4th, 2016 06:27 PM
Can you post a picture of it? Hard to say what you've got going on without seeing it. As John said, there should only be a single connection on the pump.
-Ash
Red90 May 4th, 2016 06:55 PM
Originally Posted by ben little (Post 736611)
Thanks... Yea I've looked through the manuals and my truck seems to have different colors than what the manual suggests. Could be the ex-MOD... Not sure. The wire is definitely green (solid green IIRC).
I have the MOD wiring schematic and the colors should be the same.
As Ash says a picture might help. Show where it goes.
Red90 May 4th, 2016 07:00 PM
Maybe oil temp sensor. It is supposed to be light green with green stripe.
Red90 May 4th, 2016 07:02 PM
1 Attachment(s)
Here is the MOD wiring diagram.
ben little May 4th, 2016 09:36 PM
Ugh... Thanks guys. Good news, I'm just a dumbass - looked closer at this again and figured it out.
The green wire is actually for the oil temp sensor.
