-   Series Technical Discussions (http://www.defendersource.com/forum/f50/)
-   -   Milky Oil Bath Oil (http://www.defendersource.com/forum/f50/milky-oil-bath-oil-68322.html)
Ncrover725 February 7th, 2016 05:46 PM
Milky Oil Bath Oil
1 Attachment(s)
Is there any way of achieving milky oil in the oil bath filter other than wading depth? Just changed out the oil and noticed how milky it was. I have not done any serious wading since the last change.
Attachment 141829
sonoronos February 7th, 2016 05:53 PM
moisture...lots of moisture.
If that was crankcase oil, it would be coolant (most likely)
javelinadave February 7th, 2016 06:01 PM
It is NOT a head gasket if that is what you are worried about.
Ncrover725 February 7th, 2016 06:12 PM
Originally Posted by sonoronos (Post 712858)
moisture...lots of moisture. If that was crankcase oil, it would be coolant (most likely)
Trying to figure out the source of the moisture... A tiny wading last month... Only 12-18" worth.
------ Follow up post added February 7th, 2016 08:13 PM ------
Not to worried about a head gasket. No other signs. It's my daily driver while the 110 is down. Sounds like shit but does 40 miles per day.
roverman2010 February 7th, 2016 06:43 PM
You live in Florida, like us here in Texas HUMIDITY
Ncrover725 February 7th, 2016 07:05 PM
1 Attachment(s)
Makes sense.. Based off logic and a bottle of booze. I swapped out the oil and let it go.
Attachment 141831
