-   -   Sealing holes in the roof (http://www.defendersource.com/forum/f6/sealing-holes-in-the-roof-66517.html)
burlsube November 24th, 2015 03:50 PM
Any suggestions for sealing these holes in the roof?
Currently the truck has a bunch of holes that are sealed with bolts and sealant. I'm having the headliner redone and I want to make sure they don't leak.
Grommet with sealant, seam sealer and larger piece of sheet metal epoxied and riveted in or just leave it as is?
BostonAndy November 24th, 2015 03:55 PM
I used 3m black marine sealant on my well abused roof. 2 years running and not a drop from these the holes.
burlsube November 24th, 2015 03:58 PM
Just fill the hole with and you are good?
BostonAndy November 24th, 2015 04:14 PM
what I used: Amazon.com: White 3M Marine 5200 Adhesive / Sealant 10 fluid ounce cartridge: Industrial & Scientific
edit: 1oz should do a good bit of sealing. i used black. looks like it comes in white.
Red90 November 24th, 2015 04:28 PM
If there is an actual drilled hole, I would put in a hole plug.
wanabewheelin November 24th, 2015 05:06 PM
Eco above, used the same on mine to include the sun roof. Hasn't leaked since!
Rocky November 24th, 2015 05:06 PM
Wot no Flex seal????
Uncle Douglas November 24th, 2015 05:12 PM
Glue a piece of alum on the underside/inside with WHITE 3m Marine Adhesive/Sealant 5200 fast cure. It will never leak again. how you fix it cosmetically outside is your call.
ezzzzzzz November 24th, 2015 05:55 PM
You didn't say how big a hole. There are low temp brazing alloy sticks that act like aluminum and stick really well with some proper prep work. I've used it for sealing holes and even soldered up some aluminum bulkhead fittings for the heating system in my 240Z. It's been over 4 years without a leak too.
burlsube November 24th, 2015 05:59 PM
I would say it is about an M8 or M10 sized hole. There about 15 of them clustered together through across the roof.
ezzzzzzz November 24th, 2015 06:01 PM
That's not a roof...that's a sieve.
rijosho November 24th, 2015 06:16 PM
Let's see pics
rdavisinva November 24th, 2015 07:18 PM
I had a 110 roof some idiot drilled 2 holes in for off road lamps.
When I picked up the 110, it was raining naturally and dripped water down my back for 5 hours.
The lights were positioned where water would drip on the neck of both driver and passenger.
Removed the roof, cleaned the underside and top used the aluminum fix and not only did it stick it sealed both holes.
Just to be safe, put JB Weld underneath and it hasn't leaked since 2013.
Rocky November 24th, 2015 07:21 PM
try some Dynamat or similar.
burlsube November 24th, 2015 08:27 PM
1 Attachment(s)
Allegedly the truck was used by the Austrian mountain rescue so I'm guessing maybe all the holes are for search lights or maybe a roof racks?
Attachment 135532
chrisconnie November 25th, 2015 05:29 PM
3M 5200 is wonderful stuff, but VERY permanent. Go for the 4200 if you ever hope to remove again in the future.
dave_lucas November 25th, 2015 06:54 PM
Panel adhesive the type they use now days instead of welding on new body panels.
Get some small round aluminum disks grind the spots on the roof to bare metal and cover the holes with the disks use aluminum filler on the outside.
Should be a solid permanent fix.
If you have access to a tig and the skills you could repair it proper but the above method should be easy and solid for your average person.
