-   -   Fuel Filter Swap - Figuring out Axle ID - Ideas for Radiator/Intercooler (http://www.defendersource.com/forum/f6/fuel-filter-swap-figuring-out-axle-id-ideas-for-radiator-intercooler-65586.html)
pdsftw October 14th, 2015 07:32 PM
Recently traded a member for his D90 and looking to do a little work on her. Want to do a front axle rebuild (down to the swivel balls at least) and replace the older style fuel filter with a screw on type (and replace fuel lines). Finally, I'd like to look into replacing the radiator/intercooler as they are showing some early signs of aging.
For reference, this is a 1988 D90 now fitted with a 1994 Discovery 200TDI. Originally had a 2.5TD I think.
So here is what I need to figure out:
- I cant seem to see/find/read the axle ID numbers. I have looked and I really think they are buried under paint as the front axle looks like it was rebuilt. What else could help me identify the axles so I can order the right parts? What differentiates the axles? Would a picture of a certain part help?
- I will be replacing the rotors and calipers as the ones on there are in need of servicing. Is it worth going to vented discs? I am thinking I should just keep it simple and stick with what's on there, but as I am replacing both the caliper and the rotor it could be a good time to do that.
- I took a picture the sandwich style fuel filter currently on there. I want to replace the filter, but after doing some reading it sounds like I should just replace the whole housing with a more modern screw in style filter like a Stanadyne FM-100. Does anyone have a link for good place to purchase, etc? I was thinking I might replace the fuel lines in and out of the filter as well. What lines do people like as they are nylon and traditional fuel lines? Clamp systems to look for or avoid? I see some people fit primary filters (think they call them sedimenters). Are these just insurance? Worth the cost/time?
http://i.imgur.com/VHs6Gif.jpg
As you can see, it's a little bit of a hack job on the fuel lines.
- Finally, thinking a little down the road, I think I'd like to eventually replace the radiator and intercooler. If they are both going to be replaced, what should I replace them with?
Daddymow October 14th, 2015 08:15 PM
Get ahold of Randy (A.K.A. TdiGuy) who is a vendor here and order your Radiator/intercooler/electric fan/expansion tank/silicone hose kit from him. Great quality products and Randy is a pleasure to work with.
xplorUtah October 14th, 2015 08:33 PM
Agreed
..X2
rdavisinva October 14th, 2015 10:03 PM
Show some pictures of the vehicle and engine, please.
I think I sorted out the engine in this ride before the owner pulled the plug on further investment and left from VA to TX..
Red90 October 14th, 2015 10:18 PM
On the stanadyne.
http://thedieselstore.com/stanadyne-...es-29888.html?
http://thedieselstore.com/stanadyne-...t-6-in-2m.html
Red90 October 14th, 2015 10:20 PM
On the axle. First measure the thickness of the flange of the drive flanges.
pdsftw October 14th, 2015 10:27 PM
I'm guessing that's exactly the truck - I traded Adam a truck of mine for this one. I posted some pictures in the welcome/introduction section of the forum. Sounds like you know a little about it - if be interested if you would share (here or PM) your thoughts, concerns etc in this truck.
rdavisinva November 2nd, 2015 07:43 AM
No I was wrong.
This 90 belonged to Adam and I DID NOT work on it.
I worked on one that belonged to Bobby who drove it back to TX where he sold it.
Please disregard my previous post regarding the following because it is incorrect:
