-   -   Seized rusty bolts...What did you do? (http://www.defendersource.com/forum/f6/seized-rusty-bolts-what-did-you-do-56284.html)
vw121 September 9th, 2014 10:12 PM
When I tried to drop my tank guard 90% of the bolts snapped. I tried using generous amounts of PB Blaster, heating, extractors, but they will not come out. I am thinking my only option is to cut and weld on new threaded plates/studs. Am I unlucky or is this what most people had to do?
http://img.photobucket.com/albums/v2...ps5f27320a.jpg
http://img.photobucket.com/albums/v2...ps39b6bf71.jpg
Bill Larson September 9th, 2014 10:25 PM
You've got bigger problems than rusty bolts....I would speculate that cross member isn't doing so well. But yes drill and tap is a way to go, save the welding for the cross member replacement.
javelinadave September 9th, 2014 10:36 PM
As always Bill has a very valid point. Not only is he is a Land Rover savant he is an expert marksman with a blow gun and a flame thrower. I would tap the rear crossmember with a small hammer and see what else gives way. From your photos, things don't look very sound and a rear crossmember is pretty easy to replace since you have the fuel tank already dropped.
Broncoduecer September 9th, 2014 11:04 PM
I soaked mine for days and tried an extractor. It worked for some, not all. The rest I cut off and had some of the pucks with the threaded holes made at the local blacksmith shop and welded them on.
And agree with the above comments on checking out the crossmember in general.
Brewie212 September 9th, 2014 11:10 PM
Don't sweet it, shit happens a lot with these! The faster you come to realization that it sucks and start drilling the faster you will be done! Start small and work your way up and it shouldn't take you more then a half a day:) good luck! As for the skid plate I would take an air hammer or chisel and just knock those nuts off:) haha I said it!! Good luck! Have fun with it! Bourbon always makes it more fun for me:)
scrubs September 9th, 2014 11:19 PM
Well said!!!
Bill Larson September 9th, 2014 11:46 PM
Sweet talker you...:flowers:
ezzzzzzz September 10th, 2014 08:09 AM
Wear safety glasses! One small speck of rusty metal falling into your eye will have you at the optometrist's office for extraction. It isn't fun. Been there 30 years ago.
NPT90 September 10th, 2014 08:15 AM
Lol it's funny because it's true; I always remember to wear mine, till I forget...
ron September 10th, 2014 08:19 AM
to add to the above, I have found that you can get the cradle bolts out from the top with vise grips turn to the right..... : )
ezzzzzzz September 10th, 2014 08:56 AM
If you have the resources, weld a nut onto the exposed stud and use a wrench.
