-   Truck Build-up's & Restores (http://www.defendersource.com/forum/f47/)
-   -   SIII/RRC 100" Hybrid (http://www.defendersource.com/forum/f47/siii-rrc-100-hybrid-47664.html)
SS350 August 21st, 2013 09:02 PM
Recently joined this forum after picking up a 100" Hybrid built by a local wheeler a few years back and figured I'd start a thread highlighting my plans. Some of the New England members may recognize it like this...
http://i923.photobucket.com/albums/a...roading012.jpg
The previous owner purchased it, painted it white (see thread), and then set about to make a extended cab trayback (flatbed in state-side lingo).
I had followed the original build thread where a '91 RRC Great Divide chassis became the underpinnings for a capable coiler '73 Series III 88" wagon. Wheelin pics from original build for fun... http://s923.photobucket.com/user/gt3...?sort=3&page=1
Profile shot showing orientation of Body on chassis with wheels at the corners..
https://sphotos-a-lga.xx.fbcdn.net/h..._3842609_n.jpg
Specs from ad: 1991 RRC GDE #1 is the build platform has OME springs front and terrafirma HD shocks. Has a 3.9 injected engine with Ford ignition, Ford injectors, cut velocity stacks,4.2l comp, Saudi tune resistor, advanced timing, custom exhaust no cats y'd into 3inch all mandrel bent and high exit out the side. Auto Trans in great shape!! Clean fluid shifts good. Has quiet LT230 out of a 99 DII shifts in and out of hi/low/lock very easy. Front and rear axles have series diffs converted to run 24spline axles. Rear axle has true-trac , front open. Have spare shafts to go with it.
I've found some really good Hybrid info digging around on various Rover forums... Defendersource, Devon4x4, aulro... and some on Pirate... long term I'm leaning towards a D90 windshield, tub and ROW soft top i think with the placement of the bulkhead relative to the front axle being farther back then normal on this hybrid I could end up with a non-comp cut that uses 90" tops - could have similar proportions to this... 100" wb in a 90 body (ony a 7.1" difference from stock)
http://www.defendersource.com/forum/...9&d=1276448840
from http://www.defendersource.com/forum/...=21283&page=14
short term i need to repair the seat box, floor, bulkhead, and get another dash set-up together to monitor the engine's vitals as well as wire all lights again (PO cut the harness to all but the motor in order to re-wire).. plenty to do once i complete and sell a different project car... for now it runs and drives...
SS350 August 21st, 2013 09:24 PM
Current State
Current condition...
SS350 August 22nd, 2013 07:47 AM
http://media-cache-ak0.pinimg.com/73...e7efc42b23.jpg
http://media-cache-ak0.pinimg.com/73...87edd724cb.jpg
This fall the search for a new 109 or 90" tub will start, I may stop by Overland Engineering to see if they have any parts as I think that is where the 73 originally came from. Until then I'm just researching how these Rovers go together, checking into parts I don't have (inner fender wells, floor screws) and getting a feel for which vendors have the best quality replacement seat box and floor panels.
Rocky August 22nd, 2013 08:22 AM
You're so close to having a trayback/extended cab......
SS350 August 23rd, 2013 04:33 PM
Right, I considered it but am aiming for a more family friendly wheeler/street truck.
revtor August 23rd, 2013 05:06 PM
are you going to extend the wheelbase at all or keep the rear overhang as is?
rwollschlager August 25th, 2013 11:51 PM
Glad to see this truck will be back on the road!
I know it and its former owner/builder pretty well, heck that's my series III and I in the background of that first pic, taken at the Deer Lake Rally in Killingworth CT.
To those interested, this is actually #1 of the Great Divide edition RRC's.
Good luck with the build!
-Rob
junkyddog11 August 26th, 2013 05:31 AM
-Rob
Not sure that the #1 GDE is that relevant anymore lol.
SS350 August 27th, 2013 11:08 PM
Overhang / wheelbase
My plan would be to shorten the extended frame rails back to mount either an shortened 109 or std 90 tub. Just planning on locating a tub locally (I've seen a few for sale on here for reasonable $$ but would require shipping) and spending some time on it this winter.
SS350 September 6th, 2013 02:14 PM
Nope!! I agree.
