-   For Sale - Parts (http://www.defendersource.com/forum/f9/)
-   -   drive shafts and springs (http://www.defendersource.com/forum/f9/drive-shafts-and-springs-32865.html)
Oliver Whiting August 27th, 2011 07:20 AM
4 Attachment(s)
Old Man Emu 755 110 rear springs very low milage $80 for the pair
Old Man Emu 767 front springs also low milage $80 for the pair
Rear drop shock mounts $60 pair
90 rear drive shaft, 90 front drive shaft, 110 front drive shaft, RRC front drive shaft and panhard rod $10 each
plus shipping.
Oliver
nathanwind August 27th, 2011 07:33 AM
Front and rear springs licked...just need to compare some measurements on this end (and verify shipping to 22312).
Wolf Fabrication August 27th, 2011 07:50 AM
Seconds on springs if Lav backs out
------ Follow up post added August 27th, 2011 08:54 AM ------
Wait, are you sure the front springs are 767s? I don't see them listed on the OME site
nathanwind August 27th, 2011 08:17 AM
Anyone have any idea of the compressed dimensions of these OME springs? I'm trying to compare it to my current setup on my stock springs (note: fronts are sagging which is why I need to replace, but compressed I'm at FRONT: 9.5"-9.75", REAR: 11.5"-11.75"). Unfortunately I'm limited by my current garage setup at the moment.
I'll do some more homework, but if these work I'll take them definitely.
James Pierce August 27th, 2011 08:22 AM
By compressed do you mean at ride height or coil bind?
smob August 27th, 2011 08:35 AM
Rear 90 driveshaft licked - PM coming.
nathanwind August 27th, 2011 10:01 AM
Ride height.
Trying to find spec sheets for OME...anyone have a link?
Rugbier August 27th, 2011 10:46 AM
Jason, you will be find
Oliver Whiting August 29th, 2011 11:08 AM
springs and things
plus shipping.
Oliver
90 rear drive shaft sold. Thank you.
springs are still up for grabs along with the drop shock mounts and other bits.
Wolf Fabrication August 29th, 2011 11:25 AM
Still interested in the springs. Can you confirm the front springs are 767s? OME isn't listing them.
grnrvrs August 29th, 2011 11:33 AM
OME767:
http://www.arbusa.com/uploads/PDF/ac...erDefender.pdf
p56, new naming convention 2xxx e.g. 2767
http://www.inlandrovers.com/product_p/ome767.htm
http://www.offroadexperience.com/wcb/emu.htm
They're out there.
Wolf Fabrication August 29th, 2011 12:26 PM
If Jason backs out I'll take the springs. Any idea your overall lift with those springs? 2+" ?
nathanwind August 29th, 2011 12:28 PM
Jonathan- springs are yours...I'm still doing my homework on ride height/lift and may go with an alternate set, but don't want to hold things up for Oliver unecessarily.
Oliver - got your pm's as well, I'll drop you a line soon.
Wolf Fabrication August 29th, 2011 12:35 PM
Email sent....
vlocci August 29th, 2011 03:14 PM
PM sent on the 110 driveshaft.
Vin
